Print at Sep 26, 2026, 11:57:15 AM
Posted by ggrptr at Mar 4, 2014, 10:56:10 PM
SVG export fails
Hi!
I can't get svg export to work on windows7 (x64) (oracle java version 7). I get this exception:
java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.loadClass(Unknown Source)
I tried to add lib/freehep-vectorgraphics-svg-2.1.1b.jar to jars in the html source, but it still doesn't work.
Can somebody help me to fix it?
Thanks!
Posted by Puybaret at Mar 5, 2014, 8:51:51 AM
Re: SVG export fails
Why would you add something which is already included with the program??? I feel you can't be helped if you don't tell us what you try to do and how you did it?
Posted by ggrptr at Mar 5, 2014, 4:57:35 PM
So, i simple view (over an apache server) the html page from the deploy folder, which containing the applet (after enable the svg export) . But the "export to svg" menu option throws a java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D exception. I thought that it helps to add lib/freehep-vectorgraphics-svg-2.1.1b.jar to jars list, but it doesn't. Sorry, but java isn't my strong suit, but i need this applet. In the eclipse debug it works. What do i wrong?
Posted by Puybaret at Mar 6, 2014, 9:36:35 AM
Reading SweetHome3DApplet documentation would have given you the answer: set enableExportToSVG parameter to true.
Posted by ggrptr at Mar 6, 2014, 6:53:02 PM
If it were not true, don't see the option. A more constructive reply?
Posted by Puybaret at Mar 6, 2014, 9:23:45 PM
Maybe, my English gets rusty, but I don't understand what you mean.
A nicer reply from you would be really appreciated! I'm ok to help and I helped you. If you don't want it, help yourself, it's open source! By the way, explaining why you "need this applet" would be appreciated because sharing experiences is a part of the open source world too.
Posted by ggrptr at Mar 6, 2014, 9:55:35 PM
So, sorry for my english, i'm am in hurry with the last message, and I dont speak english, it's wery difficult to me.. What I tried to say: If i can start the export, I obviously that I allowed it, no? It's not too difficulty, sorry. Can you show me a working applet with SVG export function, or it does't work at all?
Posted by ggrptr at Mar 6, 2014, 10:29:21 PM
After enabling the export, it throws this exception:
basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu: try again ..
basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.model.LengthUnit_hu_HU: try again ..
basic: JNLP2ClassLoader.findClass: com.eteks.sweethome3d.swing.HomeTransferableList: try again ..
basic: JNLP2ClassLoader.findClass: org.freehep.graphicsio.svg.SVGGraphics2D: try again ..
java.lang.NoClassDefFoundError: org/freehep/graphicsio/svg/SVGGraphics2D
at com.eteks.sweethome3d.swing.PlanComponent.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$38.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: Class org.freehep.graphicsio.svg.SVGGraphics2D
Posted by Puybaret at Mar 7, 2014, 9:19:31 AM
I just try on the online version hosted on this server with no problem (the Export to SVG menu item appears only for logged in users). Did you sign freehep-vectorgraphics-svg-2.1.1b.jar?
By the way, it would be still nice to share here why you need Sweet Home 3D applet.
Posted by ggrptr at Mar 15, 2014, 7:41:09 PM
At last I found it, the embedded jnlp file didn't conatined the right jars for the svg import. It was my fault, because I am inexperienced in this area ..
Now, I have another problem. I don't need funriture models, but only doors and windows. What furniture and texture catalogs contains these?
I downloaded the additionalFurnitureCatalog.zip, and it works, but in the catalog tree, the icons missed, replaced with a "missing image" icon..
What can I do with this?
Thank You!
Posted by Puybaret at Mar 15, 2014, 8:03:46 PM
Sorry, don't expect more help if you don't give any detail about your need of Sweet Home 3D applet.
Posted by ggrptr at Mar 15, 2014, 9:00:46 PM
I'm sorry I just don't understand how related to the intended use of the method of installation.
But, if it enough for you: my employer need an applet on his intraweb, to draw home layouts, and store it on the server, attached to homes for sale. We aren't need furnitures and decorators, only a simple layout with walls, rooms, windows and doors. The special need is to save svg file on the server. I prepared it, it works, and now tried to add windows and doors to the applet (the default deploy environment doesn't contains it), but can't figure it out, how to do this.
Posted by Puybaret at Mar 17, 2014, 8:25:04 AM
Did you try the suggestions in this subject?
Posted by ggrptr at Mar 17, 2014, 9:07:28 AM
No, unfortunately not, but now I look at, thank you.
