Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Printing problems ! |
| Print at Oct 6, 2026, 9:40:56 PM | |
| Posted by sirjeff at Mar 6, 2014, 9:13:14 PM |
Printing problems !I'm using SH 4.3 with Java on XP SP3. No problems using my design, making a video or making a picture. When I try printing, the preview doesn't work nor does Print to PDF because the file that's being printed is empty with what I can see. When I try to print to a printer it prints the furniture list and nothing else. On my screen I have everything, 3D Image and drawing also. Everything is checked to be printed in the Page Setup and of course the printer is working just fine ... I tried printing each item individually (3D, Drawing etc) but it still didn't work. Its as if it doesn't recognize my drawing or 3D image !! When I created my drawing, I just started adding walls and never created a room. Could this be the problem ? I can email anyone the drawing if they would like and try it out ?? |
| Posted by hansmex at Mar 6, 2014, 11:29:22 PM |
Re: Printing problems ! You can send me your file if you like. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by hansmex at Mar 7, 2014, 1:53:59 AM |
Re: Printing problems ! Csaba, Everything worked fine on my computer. I sent you 3 PDF's. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Mar 7, 2014, 9:14:16 AM |
Re: Printing problems ! As explained in the FAQ Sweet Home 3D refuses to print the 3D view. What can I do?, it must be a graphics card driver issue. In case you can't solve the issue, you can still make some screen captures. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sirjeff at Mar 7, 2014, 10:38:44 AM |
Re: Printing problems ! As explained in the original post, not even the drawing will print alone ... I have 4GB of RAM ! I didn't think that the drawing only was considered 3D |
| Posted by Puybaret at Mar 7, 2014, 1:24:14 PM |
Re: Printing problems ! If you read the FAQ, you'll see it's not a problem of RAM but a problem of video driver. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 9:40:56 PM |
