Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: round doors or windows in a round wall ? |
| Print at Sep 2, 2026, 1:59:38 AM | |
| Posted by Zechinha at Mar 15, 2014, 3:04:27 PM |
round doors or windows in a round wall ?Hallo to all of you, Is it possible to edit the arc extent angle-property of windows and doors fot them to fit in a round wall ? If possible, how can I do that? Thanks for your help Zechinha ![]() |
| Posted by Puybaret at Mar 15, 2014, 4:37:46 PM |
Re: round doors or windows in a round wall ? The depth of doors and windows placed on a round wall must be set manually. If needed you may want to add an additional invisible box imported as a door or window, to perform the hole in the round wall (see this example). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Zechinha at Mar 15, 2014, 7:32:44 PM |
Re: round doors or windows in a round wall ? Thanks for your quick answer Puybaret. I hope I'not being annoying, but still: could I acchieve that this fixed window also has a round shape to flush with the wall? I mean, it's not only the depth but, like by the walls, the arc-extent-angle of the choosen piece (window or door). Is it actually possible and if yes, where can I edit this property . Do I need an extra program like furniture editor ? Thanks again. |
| Posted by Puybaret at Mar 17, 2014, 8:43:37 AM |
Re: round doors or windows in a round wall ? The program isn't able to compute the hole of non rectangular doors and windows in round walls in the current version. The support of this feature would require a lot work for very very little use. You'll have to import your window with some wall parts designed in an other software like Art of Illusion. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Zechinha at Mar 17, 2014, 4:21:26 PM |
Re: round doors or windows in a round wall ? Oh, ok. Anyway, the program is really great. Thank you very much & Bye |
| Posted by okh at Mar 17, 2014, 8:25:25 PM |
Re: round doors or windows in a round wall ? With a bit of effort - and some model creation - what you ask for is possible. Maybe the windows in this example can be of help. If you can make the windows work with some stretching and fine-tuning, you are welcome to use them (license CC-BY, but I am not fuzzed...) ok PS. Sorry, copy of personal model, couldn't be bothered to add window openings etc. |
| Posted by okh at Mar 29, 2014, 11:41:02 AM |
Re: round doors or windows in a round wall ? FYI: Sourceforge 295 updated with second example of arched walls with windows. See this thread: FenĂȘtres circulaires with image of problem (in French). ok |
Current timezone is GMT Sep 2, 2026, 1:59:38 AM |
