Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Unused items |
| Print at Oct 2, 2026, 11:31:32 AM | |
| Posted by Reddog at Mar 26, 2014, 12:00:52 PM |
Unused items Hi, new to this... a couple of questions.. how do i delete unused items?... i have loads of suff clogging up my 'home furniture' list that i am not using.. i have them set to invisible at the moment, but would like to remove them entirely. and i want to create an opening fora fireplace that is not square is there a customisable rectangle somewhere? thanks, Keith |
| Posted by okh at Mar 26, 2014, 3:23:24 PM |
Re: Unused items how do i delete unused items? In home (lower left pane): Select, right-click > Delete or just DEL (but make sure plan is unlocked if items are part of base plan). In furniture list (upper left pane), imported furniture can be deleted, furniture catalogues must be removed - see this thread. create an opening fora fireplace that is not square is there a customisable rectangle somewhere? An invisible object imported as a door window, will cut a wall to the correct shape. It sounds to me that you could place your fireplace object half way into the wall (turn of magnetism with ALT) and then insert an opening (eg Service Hatch) around the opening in the fireplace - or am I missing the point?ok PS - you really had me wondering for a sec what a "fora fireplace" was, had not heard of those before ![]() |
Current timezone is GMT Oct 2, 2026, 11:31:32 AM |
