Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Different Wall Thickness (start & end) |
| Print at Oct 1, 2026, 12:23:59 AM | |
| Posted by Chevinster at Mar 28, 2014, 11:29:42 PM |
Different Wall Thickness (start & end)Sweet Home 3D is a great software & thanks. I was trying to make a pillar Type water building That start with a 10" thickness & middle of it change to 4" & again it end with 15" thickness but I was unable to do that. I managed to make a cylinder type wall since I couldn't find an option to change the wall thickness in start & end. If there is a way to do that please advice step by step how to proceed. If you don't understand what i want to do I have attached 2 images. I think if you can add an option to change the the wall thickness in begging of wall & end of wall differently you are making this software open for new creative designs. Thanks in advance Chevinster ![]() |
| Posted by okh at Mar 29, 2014, 8:46:59 AM |
Re: Different Wall Thickness (start & end) Would two curved walls running next to each other - an inner and an outer wall - do the trick? ok |
| Posted by Chevinster at Mar 29, 2014, 12:21:04 PM |
Re: Different Wall Thickness (start & end) ya can try but not the best thing or wont give the smooth look. |
| Posted by harbinger at Apr 10, 2014, 8:56:15 PM |
Re: Different Wall Thickness (start & end) You'll probably have to do what i was forced to do: model an object in a 3rd party CAD or 3D modeling application & import it into the furniture library. In that case you'll have a lot more control -- you just have to save it in a format that SH3D can handle (i HIGHLY recommend OBJ with an accompanying MAT file). Our dear programmer must keep a balance between ease of use and user "customizability." So i don't know if the ability to dictate exact wall dimensions at all points would be viable with his overall vision for SH3D. I would however would love walls that fade to different thicknesses... |
| Posted by Puybaret at Apr 11, 2014, 8:49:45 AM |
Re: Different Wall Thickness (start & end) As the attached example shows you can play with multiple walls with a different thickness to get something that would look like you want a little. But it requires some big efforts to draw it, and I would keep that trick only for this simpler case. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 12:23:59 AM |
