Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Direct3D not working |
| Print at Sep 29, 2026, 2:53:50 AM | |
| Posted by hal9000 at Apr 3, 2014, 11:47:44 AM |
Direct3D not working Hello. Not sure if this thread should go here or under the "installation" subforum. I just upgraded from SH3D 4.1 32b to 4.3 64b. I was using this SweetHome3D.l4j.ini: -Xmx1024mIt worked fine with 4.1 32b, but when I try to open 4.3 64b with it all that I get is the splash screen and the application never starts. If I remove (or comment with #) the line "-Dj3d.rend=d3d" then the application starts normally. Could I do something to fix it? Thanks. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by Puybaret at Apr 3, 2014, 1:50:51 PM |
Re: Direct3D not working Sorry, the DirectX workaround is available only for Windows 32 bit. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Apr 3, 2014, 1:54:49 PM |
Re: Direct3D not working If you absolutely need to run Sweet Home 3D 4.3 with DirectX, you can install Java 32 bit and run SweetHome3D-DirectX.jnlp with javaws.exe found in Java 32 bit install folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hal9000 at Apr 3, 2014, 2:34:37 PM |
Re: Direct3D not working OK, thanks Emmanuel. In fact is not a great problem, usually I don't bother about Direct3D or OpenGL, as I don't see too many difference for the rather simple 3D visualization of the virtual visit mode. I just left it using Direct3D because that way the 3D output can be processed by Tridef 3D Ignition to generate a stereoscopic realtime image which can be viewed as a 3D image in a 3D monitor. Nevertheless that's not something I do frequently, it's rather a curiosity, so if I need to do it again I'll do it the way you said. Regards. ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by hal9000 at Apr 4, 2017, 2:11:02 PM |
Re: Direct3D not working Hello. I came back to this old post because I'm noticing something weird with the 3D visualisation. I'm using an old ATI Radeon HD 4350, which doesn't have support from AMD for Windows 10, so I'm using it with the driver which is installed from Windows Update, with versión 8.970.100.9001, as said in this AMD's article: http://support.amd.com/en-us/kb-articles/Page...000-and-older-Series.aspx But I noticed when I try to move around in the 3D view it does very slow and jumping from a position to the next instead a continuous movement. Although the graphic card is not very powerful it was working fine with Windows 7, so I was wondering if this Windows Update driver is not using acceleration for OpenGL and instead it's making a software emulation. I was about to test SH3D in D3D mode, but then I remembered this post about the impossibility to make it in 64 bit mode. Is still not possible with latest version of SH3D? P.S.: OK, I just noticed the "about" dialog says "version 5.4 DirectX", but then I cannot understand that poor performance on 3d view... ![]() ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
Current timezone is GMT Sep 29, 2026, 2:53:50 AM |
