Print at Oct 1, 2026, 11:28:12 PM
Posted by Dares at Apr 8, 2014, 10:28:03 AM
How to install SweetHome 3d on website
Hello I' have simple question.. I need only web version of Sweet Home to embed on site as Online version on this site. Can anybody to get a step by step solution to do this? Im not a programmer in Java.
Posted by Puybaret at Apr 8, 2014, 5:23:07 PM
Re: How to install SweetHome 3d on website
If you don't know Ant and Java compiling process, this is going to be very hard for you.
Why do you need it?
Posted by Dares at Apr 9, 2014, 8:07:04 AM
I have website to sale project and sale of furniture to kitchen but I need aplication to simple draw and give dimensions of room for hand-crafted furniture. Im webmaster but I dont work with Java. Can anybody help to compile online version of program?
Posted by Dares at Apr 14, 2014, 11:52:35 AM
Any help? Maybe someone can compile web version?
Posted by Puybaret at Apr 14, 2014, 1:26:54 PM
Did you already try to install the Sweet Home 3D viewer. That would be a first step...
Posted by Dares at Apr 14, 2014, 6:37:12 PM
Yes i did it and work but it only show project without create or edit project. I need it for create wall and simple accomodation nothing more. What next step ? Please help
Posted by Puybaret at Apr 14, 2014, 9:37:57 PM
If you want to edit an online project then save it and reopen it later, you need to have a dynamic web server using PHP, JSP or similar technology. Are you able to handle such tools?
Posted by Dares at Apr 15, 2014, 6:13:24 AM
Yes, I able, what next?
Posted by Dares at Apr 15, 2014, 6:19:33 AM
Sweet home viewer test: http://wirtualne-studio-mebli.pl/test/SweetHome3DViewer.html
Posted by Puybaret at Apr 20, 2014, 2:58:52 PM
If you were able to install Sweet Home 3D viewer, it should be not too difficult to install Sweet Home 3D Online instead, just by comparing the source code of the viewer with the online version.
Posted by Dares at Apr 22, 2014, 12:40:40 PM
Yes ok, but where i cant find SweetHome3DApplet.jar ?
Posted by Dares at Apr 25, 2014, 12:37:25 PM
Ok I solve my problem. Thanks any help
Posted by susonne at May 22, 2014, 10:43:18 AM
Hallo,
I would also like to install SH3D online, I installed the Viewer sucessfully.
I don't really understand which source codes I need to compare. Where is the source code of the online version?
Sorry if my question was unqualified...I really tried to figure out!
I work with java and eclipse, but I am still a beginner I guess.
Greetings
Susanne
Posted by Puybaret at May 22, 2014, 11:56:12 AM
The source code of Sweet Home 3D, the online version and the viewer are in the same project available here.
To build the jar files of the online version, select the file build.xml and choose Run > External Tools > External Tools Configuration… menu item in Eclipse. In the dialog that opens, select the target named applet in the Targets tab, and select a JDK (not a JRE) in the JRE tab, then click on Run.
As explained in README.TXT file, note that you'll need first to create or retrieve a keys.keytool file to sign the applet jars (this keystore file will have to be named keys.p12 in the coming version).
Posted by susonne at May 22, 2014, 6:37:31 PM
Thank you for the detailed answer!!! I will try as soon as possible!!!
And anyways thanks for this really cool application!!!
Posted by susonne at May 30, 2014, 10:49:07 PM
Great! It works! Thank you again!
I have one extra question, is it somehow possible to add an extra plug-in to this online version?
I want to demonstrate a really small plug-in for an exam next week.
Posted by Puybaret at Jun 1, 2014, 9:42:04 PM
Yes, but I didn't try it for a while.
See pluginURLs in SweetHome3DApplet javadoc.
As there's no menu in the applet, keep in mind that you should set plug-in small icon to get an access to it in the tool bar.
Posted by Just_MAX at Aug 25, 2014, 2:10:01 PM
Hi!
Compiled and signed files,
After uploading files on site i got error:
JNLPSigningException
Failed to validate signing of launch file. The signed version does not match the downloaded version.
Any idea how to fix it?
Posted by Just_MAX at Sep 10, 2014, 4:40:26 AM
Compiled older version 4.3 and it works fine
Posted by Puybaret at Sep 11, 2014, 5:24:50 PM
For security reasons, Oracle now recommends (and might obliges one day) to include the APPLICATION.JNLP file of the applet in its main jar. That's the main change I performed in Sweet Home 3D applet version 4.4 (see diff with version 4.3 here).
So, if you want to change the libraries you need in your version of the applet, you'll have to update the file SweetHome3DApplet.jnlp found in deploy subfolder, then update jnlp_embedded parameter and jars variable in SweetHome3DApplet.html.
Posted by Just_MAX at Sep 14, 2014, 8:07:58 AM
Did it, thanks for pointing in right direction
Posted by Just_MAX at Sep 26, 2014, 3:40:42 PM
I found PDF saving function doesn't work in my case, same as creating photo with date and time parameters,
any clues what is wrong?
Posted by Puybaret at Oct 7, 2014, 1:09:33 PM
- If you want Print to PDF feature, you have to set enablePrintToPDF applet parameter to true, and add iText-2.1.7.jar signed library to jars list (in the applet parameters as well as in the JNLP file).
- If you want photo creation feature, you have to set enableCreatePhoto applet parameter to true, and add sunflow-0.07.3i.jar signed library to jars list.
- If you want video creation feature, you have to set enableCreateVideo applet parameter to true, and add jmf.jar signed library to jars list.
- If you want Export to SVG feature, you have to set enableExportToSVG applet parameter to true, and add freehep-vectorgraphics-svg-2.1.1b.jar signed library to jars list.
Look at the Online version on this web site for a real world example (requires that you are logged in).
Posted by Just_MAX at Oct 8, 2014, 3:57:12 AM
Did it before, but keep receiving errors about jnlp files mismatch (checked - it was same, files cache renewed, java cache disabled)
And it worked after i sent you a message. Strange thing
Posted by efodi at Feb 20, 2020, 10:32:26 AM
Hi!
I have installed Java Version 8 Update 241 for using Sweet Home 3D online version, but i still receive the following error:
Unable to load resource: http://www.sweethome3d.com/lib/SweetHome3DApplet.jar
If i try independent to download the .jar i have no problem with it.
It looks like only the site it self has problem with his own .jar.
I'm using a Win10 with IE11.
Could somebody please help me here?
Thank you!
