Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: ground elevation and sloping wals |
| Print at Sep 30, 2026, 5:20:18 PM | |
| Posted by tumad at Apr 29, 2014, 10:54:01 AM |
ground elevation and sloping walsIt would be nice if we could give a start and end ground elevation. It would also be nice if we could give sloping walls not only from the top but also from the bottom. Another missing feature is to create a movie from Aerial perspective. Thanks all for great software |
| Posted by okh at Apr 29, 2014, 3:49:36 PM |
Re: ground elevation and sloping wals It would be nice if we could give a start and end ground elevation. Sloping terrain would be a nice feature that would have helped my mountain project initially. But, as you have probably figured out, there are several workarounds. See this link (4817) and more.It would also be nice if we could give sloping walls not only from the top but also from the bottom. For those rare occasions, don't you think the (fairly) straightforward workarounds will suffice? Such as:- Drawing a sloped wall, export as OBJ, import and rotate. - Using an invisible triangle (or whatever) imported as a window/door to make a cutout in the wall. Just my 2p worth. ok |
Current timezone is GMT Sep 30, 2026, 5:20:18 PM |
