Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problems with creating photos on Q3 and Q4 |
| Print at Oct 4, 2026, 7:54:31 PM | |
| Posted by Markoz83 at May 12, 2014, 6:56:19 PM |
Problems with creating photos on Q3 and Q4 Hello. I'm a new user of this fantastic software. Since 2 days ago everything was ok but now, when I try to create a photo on quality 3 or 4 nothing happens, why?????I use a mac book pro with Lion and i updated Java to version 7. Thank you for your answer. |
| Posted by Puybaret at May 13, 2014, 10:52:06 AM |
Re: Problems with creating photos on Q3 and Q4 Updating to Java 7 won't change anything since the installer version still uses Apple Java 6 until now. Java 7 is used only for the Mac App Store version but even in that case, installing/updating Java 7 on your system won't change anything, because that version of Sweet Home 3D comes with its private copy of Java. To fix your problem, you should try to increase the max memory the program is allowed to use following instructions in the FAQ. Hope you can handle it... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Markoz83 at May 13, 2014, 9:58:39 PM |
Re: Problems with creating photos on Q3 and Q4 Wonderful!I updated the memory from 1024 to 2048 and it works again!Thank you so much!I dind't see the questions on the FAQ page. Thank you so much! |
| Posted by julss16 at May 22, 2014, 9:44:16 PM |
Re: Problems with creating photos on Q3 and Q4 Hello, I've the same Markox83's problem, but I use Linux (ubuntu 14.04 LTS). Following the FAQ I've read "Under Linux, edit SweetHome3D script, update the 1024 value in the option -Xmx1024m, save the script, then relaunch Sweet Home 3D."...but I dont understand how can I do it. Someone can help me? Thanks! ---------------------------------------- Giulia |
| Posted by Puybaret at May 23, 2014, 8:19:44 AM |
Re: Problems with creating photos on Q3 and Q4 The SweetHome3D script is a text file. When you double click on it, Ubuntu should propose you to run it or display it. Choose to display it, then search for 1024, replace it by the value you want to test, save the file, and run it again. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by julss16 at May 25, 2014, 11:01:40 AM |
Re: Problems with creating photos on Q3 and Q4 Thanks Puybaret, but where is this text file? I'm sorry but I don't find it... ---------------------------------------- Giulia |
| Posted by Puybaret at May 25, 2014, 12:26:00 PM |
Re: Problems with creating photos on Q3 and Q4 You can find it in the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by julss16 at May 25, 2014, 3:38:51 PM |
Re: Problems with creating photos on Q3 and Q4 ohhh!! I've finally find it! thanks Puybaret!!! thanks a lot!! But the problem is unresolved.... In the terminal "Exception in thread "pool-18-thread-1" java.lang.OutOfMemoryError: GC overhead limit exceeded" out of memory....probably my 4G are less then how much is necessary for this program. The project is on 4 level... ---------------------------------------- Giulia |
Current timezone is GMT Oct 4, 2026, 7:54:31 PM |
