Print at Oct 10, 2026, 2:22:50 AM
Posted by laurenz at May 29, 2014, 7:33:32 AM
How to change overall size?
I received a plan of a flat which was said to be exactly 1:100.
So I
- imported it as background
- created the rooms to match the background size
And found that the room sizes all did not exactly match the ones I had been given.
I then actually measured some walls. I turns out thta everythin in reality is slightly bigger than on the plan - the scan I started out with is not 1:100 but 1:107,56.
It is easy to change the size of the background image, but how can I change the size of all rooms to match?
I grouped everything but I only can move the group against the background I do not find a way of adapting the size of the whole group. Is there a way of achieving this without redrawing all rooms?
Posted by hansmex at May 29, 2014, 12:35:39 PM
Re: How to change overall size?
From the Documentation page, download the Plug-in tutorial and install the AdvancedEdit plug-in.
Posted by okh at May 29, 2014, 12:45:48 PM
There is a plugin (described in Hansmex' plugin guide) that allows various advanced editing features - resizing being one. The plugin is very useful, but be careful to save your work as the results sometimes can be a bit strange.
IF you have several levels, you may also want to try the latest beta of SH3D where you can select across levels. Just tried resizing a multiple level design to 107,5% and it worked like a charm....
