Print at Oct 3, 2026, 5:00:26 PM
Posted by enzoleva at Jul 18, 2014, 2:41:13 PM
No rendering, only black window
Help me, please! Suddenly the rendering of the program doesn't work, I believe after having installed Xampp, also when this program is not on. I have also tried to re-install Java, DirectX and the same program, but nothing doesn't change.
Practically, to the rendering is overlapped a black screen, and if you can sometimes see something, they are only gray and white blocks. What can I do?
Thank you anticipate to whom helps me to recover this program.
Posted by hansmex at Jul 19, 2014, 9:32:07 AM
Re: No rendering, only black window
Maybe you can send me your file?
Posted by mataha at Aug 25, 2014, 1:11:04 PM
yes my problem like as enzoleva. blackscreen in 3D view. i just update 3D rendering, java etc, but nothing change.
Posted by Puybaret at Aug 25, 2014, 4:15:44 PM
What size and quality did you try?
Posted by mataha at Aug 26, 2014, 3:47:08 PM
this my spec computer intel pentium 4 CPU 1.8GHz Memory 512Mbytes Graphic NVIDIA GeForce FX 5500 256MBytes. Setting grapics screen resolution 1440 by 900 pixels.
Posted by mataha at Aug 29, 2014, 12:35:04 PM
i found how to 3D view. you must update latest version of VGA driver. i`m use nvidia gefoce FX 5500 (too old VGA hahah) but update VGA driver is best solution. soo no more black window at 3D view
