Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Import 3D format |
| Print at Sep 26, 2026, 11:11:47 PM | |
| Posted by choppyleo at Jul 24, 2014, 8:59:45 AM |
Import 3D formatHello, Is it possible to import 3D format directly into Sweet Home 3D software. Or if not yet how can it be done to add these function. Thanks a lot! |
| Posted by Puybaret at Jul 24, 2014, 9:36:08 PM |
Re: Import 3D format Basically, you should decode the file format you want to import, then try to create Wall and Room instances that the imported data contains. Finally, add these objects to a new Home instance that you'll display at the screen by inspiring you from SweetHome3D main class source code. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by choppyleo at Jul 25, 2014, 2:18:41 PM |
Re: Import 3D format Thanks But is there a code already on your reply? I will love to have it and see how it is implemented. |
Current timezone is GMT Sep 26, 2026, 11:11:47 PM |
