Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Where do these lines come from? |
| Print at Oct 3, 2026, 11:07:10 PM | |
| Posted by wampe1 at Jul 24, 2014, 12:29:10 PM |
Where do these lines come from? Hallo zusammen, kann mir jemand helfen? Wie bekomme ich diese Linien weg? http://www.fotos-hochladen.net/view/linesdoq0nvtkp4.jpg Wenn ich das 3D Modell drehe, sind diese Linien weg. http://www.fotos-hochladen.net/view/ohnelines5utcrdf41m.jpg In der 3D Ansicht "virtuelles Begehen" sind diese Linien auch da und stören die Innenansicht. Danke & Gruss, Vitali ### Hi there, can someone help me? How do I get these lines off? http://www.fotos-hochladen.net/view/linesdoq0nvtkp4.jpg If I turn the 3D model, these lines are gone. http://www.fotos-hochladen.net/view/ohnelines5utcrdf41m.jpg In the 3D view "virtual toast" these lines are also there and disturb the Interior. Thanks & Greetings, Vitali |
| Posted by Puybaret at Jul 24, 2014, 9:18:16 PM |
Re: Where do these lines come from? These "lines" are ceilings that Sweet Home 3D didn't succeed to compute correctly because the shape of the room is probably too complicate. To remove them, simply double click on each room of the last floor and unselect the "Display ceiling" check box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wampe1 at Aug 8, 2014, 2:17:33 PM |
Re: Where do these lines come from? Hello Emmanuel, thank you! The problem is solved through your post! I am very happy :-))) Kind regards, Vitali |
Current timezone is GMT Oct 3, 2026, 11:07:10 PM |
