Print at Sep 24, 2026, 9:12:18 PM
Posted by choppyleo at Aug 11, 2014, 1:01:13 PM
Problem of executing the source code on eclipse
I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage
Exception in thread "main" java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte)
at java.io.FileInputStream.open (Native Method )
at java.io.FileInputStream.<init>(Unknown Source)
at org.freehep.util.io.ASCII85InputStream.main
(ASCII85InputStream.java:147 )
Posted by Puybaret at Aug 11, 2014, 1:11:21 PM
Re: Problem of executing the source code on eclipse
You mixed up "Program arguments" and "VM arguments" in eclipse run configuration.
Posted by choppyleo at Aug 11, 2014, 1:24:29 PM
Thanks, I have corrected that and now seeing this:
Usage: ASCII85InputStream filename
Posted by sree.arun.kr at Aug 11, 2014, 1:41:54 PM
Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?.
[* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ]
Intreasted to learn and tweak. angel
Thanks in advance. applause
Posted by choppyleo at Aug 11, 2014, 2:06:33 PM
I think I know how to creat that but I don't know how your reply is helpful to my question. Thanks
Posted by sree.arun.kr at Aug 11, 2014, 2:17:39 PM
Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer.
All kinds of tips are welcome. applause
Posted by choppyleo at Aug 11, 2014, 2:25:34 PM
Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks
Posted by sree.arun.kr at Aug 11, 2014, 2:35:52 PM
Question is simple
When I get the SH3D sourcecode then how to build a jar application using Eclipse.?
If you are successfull to create a sweethome3d.jar then share the methods you used.
Thats it. applause
Posted by choppyleo at Aug 11, 2014, 2:57:50 PM
If you have already imported the source code on eclipse(but if not then follow the step of the Readme file).
After doing so then follow the steps on then site: http://www.wikihow.com/Create-an-Executable-File-from-Eclipse
Good Luck
Posted by sree.arun.kr at Aug 11, 2014, 3:29:18 PM
Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scriptingpeace
Posted by Puybaret at Aug 11, 2014, 4:33:11 PM
at ...
at org.freehep.util.io.ASCII85InputStream.main (ASCII85InputStream.java:147 )
What about running a main class with a name that looks like Sweet Home 3D, maybe… com.eteks.sweethome3d.SweetHome3D
Posted by banna at Feb 15, 2017, 1:18:57 AM
Hi
Choppyleo!
I am also getting the same problem.
How to solve?
Can you please guide me?
Posted by Puybaret at Feb 16, 2017, 8:41:18 AM
As already suggested, run the com.eteks.sweethome3d.SweetHome3D main class.
Posted by Dhel at Feb 18, 2017, 4:44:18 PM
Same concern, how can i embed and make an applet of sweet home 3d? thank you!
Posted by Puybaret at Feb 18, 2017, 9:50:43 PM
Dhel, applets are almost dead. You shouldn't invest time on this deprecated technology.
