Print at Sep 30, 2026, 9:40:29 AM
Posted by bbos at Aug 16, 2014, 11:55:49 AM
Disabeling editing options from furniture
Is it possible to disable furniture resizing?
thanks!
Posted by SnakeGB at Aug 18, 2014, 6:29:03 PM
Re: Disabeling editing options from furniture
why would you want too?
Posted by okh at Aug 19, 2014, 10:49:06 AM
I guess this is useful if you want to provide real-life furniture that comes in one size only. Yes, it is doable. Create a furniture library with the Furniture Library Editor, add your model and save. Then you must edit the PluginFurnitureCatalog.properties file (within the library - zipped) and add/edit a property of the model:
resizable#nn=false
where nn is the numeric identifier of the model (just look at the other properties for the model).
Not for casual use, of course, but not that difficult if you want to provide furniture in a catalogue.
For more information on the properties, check out the DefaultFurnitureCatalog.PropertyKey.
Posted by bbos at Aug 26, 2014, 8:26:45 PM
Thank you very much!
Posted by okh at Aug 26, 2014, 9:51:18 PM
If you are working on a project with real life models, please share. I guess many users could be interested. Good luck.
PS If you figured out how to disable re-sizing from the very superficial response, I guess you don't need luck as far as your models are concerned smile
