Print at Sep 25, 2026, 11:02:29 PM
Posted by solidrock68 at Aug 22, 2014, 2:46:41 PM
Object problems
Hi all! Just started to use Sweet Home 3D and have made some stuff.
Today i edited a object in Sketchup and all looked fine when i exported the object. But when i open it in Sweet Home 3D somethings in the object looks inverted. Weird thing is that i didn“t change any materials or other stuff. Just moved some parts of the main object. I can send a copy of the object for inspection.
Posted by hansmex at Aug 23, 2014, 7:50:34 AM
Re: Object problems
Solution (probably) will be to export the model again from Sketchup, but this time first choose Options and make sure that you select Export two-sided faces.
