Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Is there a maximun file size for sh3d files? |
| Print at Oct 2, 2026, 7:42:07 PM | |
| Posted by Arnoud at Aug 26, 2014, 9:19:41 PM |
Is there a maximun file size for sh3d files? Lately I've added a lot of new objects by grouping and texturing boxes and cylinders into custom objects. The sh3d has grown to 67.794 kB. Now I can't render pictures anymore, the rendering just freezes in the inital phase. |
| Posted by hansmex at Aug 27, 2014, 12:30:30 AM |
Re: Is there a maximun file size for sh3d files? Try these: - read the FAQ and do the XMX trick - delete half of your models, then try to make a render; if it works, probably one of the deleted models is faulty. If not, restore your deleted models, delete the other half, and repeat the procedure. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Arnoud at Aug 28, 2014, 12:19:20 AM |
Re: Is there a maximun file size for sh3d files? The XMX trick did the trick partially. I can now render a picture but can't save it. Th program freezes at that poit, will try deleting models tomorow. |
| Posted by Puybaret at Aug 28, 2014, 12:22:45 AM |
Re: Is there a maximun file size for sh3d files? Do you use a 32 or 64 bit system? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Arnoud at Aug 28, 2014, 6:43:42 PM |
Re: Is there a maximun file size for sh3d files? I have Windows 7 64 bit. Until this week I din't have this problem... |
| Posted by Puybaret at Aug 28, 2014, 7:20:27 PM |
Re: Is there a maximun file size for sh3d files? Why happens when you try to save the image? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Arnoud at Aug 29, 2014, 11:57:25 PM |
Re: Is there a maximun file size for sh3d files? That's just what bothers me, why a freeze when I only want to save the rendered picture? |
Current timezone is GMT Oct 2, 2026, 7:42:07 PM |
