Print at Oct 10, 2026, 5:53:06 PM
Posted by PeterWeber at Aug 29, 2014, 11:25:18 PM
rose   I found the rooms to be much smaller in 3D view than they are.
Whenever I used a floor plan of a flat in sh3d as a background and later on walked through it using the 3D view the areas were always smaller than they are.
Why is that and what to change?
Posted by okh at Aug 31, 2014, 3:34:52 PM
Re: I found the rooms to be much smaller in 3D view than they are.
Not sure what you mean. Were the dimensions in the 2D plan correct? If not, you may have to re-scale your plan. As for the walk-through (virtual visitor), could it be a question of perspective? Does it still look wrong if you adjust the field of view? ok
Posted by PeterWeber at Sep 2, 2014, 4:46:35 PM
What fov should I use to have a real life perception?
Posted by okh at Sep 2, 2014, 9:51:51 PM
Well, that depends on your personal perception of your own field of vision. I tend to find that the default is a bit narrow minded for my taste - and increase the FOV by 10-30%. But a again, it is up to you, but you should see a difference if you try to increase it. See if it works smile - and good luck. ok
