Print at Sep 30, 2026, 5:27:26 AM
Posted by tribhome at Oct 4, 2014, 10:53:49 PM
Interior/Exterior Door Visibility 3D
I've created a room with an entry door and a closet door. In the 3D view, both doors look like entry doors. How can I make it so that in 3D view only the entry door is visible from the outside of the room, yet leave the closet door only visible on the inside of the room?
Posted by okh at Oct 6, 2014, 7:01:13 AM
Re: Interior/Exterior Door Visibility 3D
If I understand correctly, couldn't you draw the closet with thin walls so the closet door opens into the closet only? Or if you just want the illusion of a door on a wall - disable magnetism (press ALT) and move the door slightly in towards the room. ok
