Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: creating curved lines |
| Print at Oct 16, 2026, 7:24:16 PM | |
| Posted by prettyrustic at Oct 24, 2014, 10:17:13 PM |
creating curved lines I have a round kitchen and all the cabinets run along the outside wall. How do I create curved countertops for my kitchen cabinets? |
| Posted by okh at Oct 25, 2014, 5:42:07 PM |
Re: creating curved lines If you cannot find a suitable model (or geometric shape that matches) online, you could: - Open a new sh3d file. - Draw (thin) walls with arc extents set correctly to outline your countertop. - Close off walls, to create a "room" with shape identical to your countertop. - Use room-tool, double-click to create a room within the walls. - Select the room, export selection to .obj format. - Import the .obj file as furniture (adjust "countertop" thickness and elevation). It requires some accurate measuring and tweaking to get perfect, but once you get the hang of it, it is not too hard. Good luck. ok |
Current timezone is GMT Oct 16, 2026, 7:24:16 PM |
