Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: App doesn't run |
| Print at Oct 4, 2026, 2:36:56 PM |
| Posted by Puybaret at Apr 14, 2017, 9:58:35 PM |
Re: App doesn't run As reported here, the JRELoadError probably happens on case sensitive systems. To fix it, click on the application icon of Sweet Home 3D while maintaining the ctrl key pressed to display its contextual menu, choose Show Package Contents item, open the Contents folder and rename the folder Plugins as PlugIns (with an uppercase I). This issue will be fixed in versions > 5.4.1. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by freundreiter at Jul 4, 2017, 12:19:46 PM |
Re: App doesn't run Fixed in last update, thx. a lot!!! |
| Posted by Puybaret at Jul 4, 2017, 10:47:04 PM |
Re: App doesn't run You're welcome. Thanks for your feedback ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 2:36:56 PM |
