Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: 4 walls , |
| Print at Oct 15, 2026, 5:37:46 PM | |
| Posted by hrk at Nov 10, 2014, 12:19:19 PM |
4 walls , hi. i'm new to this forum , 1. i have 4 texture for 4 side of the wall. How do i achieve this? 2. how do i donate a small token to this cause ? good job on this. impressive. thanks |
| Posted by Puybaret at Nov 10, 2014, 8:35:08 PM |
Re: 4 walls , Welcome, 1. i have 4 texture for 4 side of the wall. How do i achieve this? If you count the top and the bottom of a wall, you could even wonder how to set the 6 sides of a wall! But I guess you want to change only the vertical parts. As Sweet Home 3D offers to change only the left, right and top sides, you'll have to create very thin walls that you put at each end of the main wall. 2. how do i donate a small token to this cause ? good job on this. impressive. Thanks. ![]() You can use the Donate button found at the bottom of each page, or go to the Donate page. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at Nov 10, 2014, 9:15:43 PM |
Re: 4 walls , 4 texture for 4 side of the wall. How do i achieve this Maybe I misunderstand, but you can 1. split walls and assign different textures to different wall elements, 2. use a picture editor and edit the textures before applying them, see thread 5438 ok |
| Posted by hrk at Nov 11, 2014, 2:17:29 AM |
Re: 4 walls , thanks guys ! i got it. just do 4 walls,joint them and apply 4 diff textures. i was meddling with rooms no wonder the issue . cheers |
Current timezone is GMT Oct 15, 2026, 5:37:46 PM |
