Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create Video |
| Print at Oct 16, 2026, 10:40:31 PM | |
| Posted by WriterBLAlley at Nov 10, 2014, 5:03:31 PM |
Create Video How do I set the length of a video? No matter what points I set, it always makes an 8 second video. |
| Posted by Puybaret at Nov 10, 2014, 8:28:46 PM |
Re: Create Video Strange... Does even a very short path lead to a 8 second video??? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by WriterBLAlley at Nov 10, 2014, 11:01:53 PM |
Re: Create Video I tried two points, still 8 seconds. I made one past where I want to go, but that made it 10 seconds. I just want to get from one point to another in about 2 to 3 seconds |
| Posted by Puybaret at Nov 13, 2014, 11:02:33 AM |
Re: Create Video The duration doesn't depend on the number of points, but on the distance on the path, since the speed is constant at 2.4 km/h. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by WriterBLAlley at Nov 13, 2014, 6:29:33 PM |
Re: Create Video Then I can't do what I need to. It'd be more versatile to have each point be one second. Then I can set the specific time over a set path, or even pause by setting the same point multiple times. |
| Posted by Puybaret at Nov 14, 2014, 1:11:00 PM |
Re: Create Video Nice idea but I fear it would be way too complicate for the end users in many cases. In case you didn't notice it's also to possible to turn the camera during a move, and globally the video is computed to ensure that camera moves are as smooth as possible. In all cases, you can always edit the computed video with an other software. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 16, 2026, 10:40:31 PM |
