Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Creating video no video |
| Print at Oct 3, 2026, 10:34:11 PM |
| Posted by JadeL at Nov 13, 2014, 6:03:13 AM |
Creating video no videoGood day I made sure when i create my video that all movement points are created but after the video is created i save the file (default file format is .MOV ) its creates a 0KB .mov file and there is no video after 10min of creating a video. Please help. Thanks in advance Jade |
| Posted by Puybaret at Nov 13, 2014, 11:00:30 AM |
Re: Creating video no video So to follow your previous post, you seem to be able to save the MOV file now, even if it's empty, right? What did you change? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by JadeL at Nov 13, 2014, 11:25:14 AM |
Re: Creating video no video Hi there Emmanuel with previous tread -- could not get it to work so all i did in this post is installed program on another hardrive instead of C drive i installed in D drive with no windows on D drive. Yes i can save MOV file now but its empty why does this happen.. |
| Posted by Puybaret at Nov 13, 2014, 11:55:41 AM |
Re: Creating video no video If I knew the answer, I would have given it already! Did you try to create a SweetHome3D.l4j.ini as suggested in my previous answer? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by JadeL at Nov 13, 2014, 12:47:06 PM |
Re: Creating video no video yes i did and copied it in the c:/programs files/sweet home 3d/ and still doesn't work. Actual fact it doesn't even open the program |
| Posted by Puybaret at Nov 13, 2014, 4:28:18 PM |
Re: Creating video no video Hum, Jade, I'm ok to help you, but if you don't report the problems you encountered with the suggestions I made, then open an other (angry) thread to complain again, it's not going to be easy... ![]() Are you sure that you didn't forget the hyphen in front of Dcom.eteks.sweethome3d.tools.temporarySubFolder....? Without it, it can't work... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by JadeL at Nov 14, 2014, 7:00:49 AM |
Re: Creating video no video Hi Emanuel. This is how i did it is it correct : -Dcom.eteks.sweethome3d.tools.temporarySubFolder=C:\temp\ Please advise if correct Thanks ![]() |
| Posted by JadeL at Nov 14, 2014, 7:01:29 AM |
Re: Creating video no video the file name is SweetHome3D.l4j.ini rename txt file to .ini |
| Posted by JadeL at Nov 14, 2014, 7:02:10 AM |
Re: Creating video no video copied in program files / sweet home 3d |
| Posted by Puybaret at Nov 14, 2014, 12:42:09 PM |
Re: Creating video no video This is how i did it is it correct : This sounds correct if C:\temp folder exists-Dcom.eteks.sweethome3d.tools.temporarySubFolder=C:\temp\ Please advise if correct ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 10:34:11 PM |
