Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: 4.5 Portable Version asking por JAVA in MAC OS |
| Print at Sep 1, 2026, 11:39:58 AM | |
| Posted by naskar at Nov 20, 2014, 7:44:35 PM |
4.5 Portable Version asking por JAVA in MAC OS Hi! I've downloaded the portable version (4.5) os sweet home 3d, since it appears to work without JAVA installed in my system. However when I start the app, it claims to install JAVA SE 6. How can I fix this? (I don't want to install JAVA on my system) I'm running OS X 10.9.5 Thank you! |
| Posted by Puybaret at Nov 20, 2014, 10:33:58 PM |
Re: 4.5 Portable Version asking por JAVA in MAC OS In the case of Mac OS X, it requires to install Java 6. If you don't want to install it, then don't use the portable version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by naskar at Nov 20, 2014, 11:05:00 PM |
Re: 4.5 Portable Version asking por JAVA in MAC OS Thanks for the response. Is there any version bundled with java? By the way, congrats for the app!! |
| Posted by Puybaret at Nov 21, 2014, 7:47:35 AM |
Re: 4.5 Portable Version asking por JAVA in MAC OS A free version bundled with Java doesn't exist under Mac OS X yet, but I really don't see the problem to install Apple Java 6. Mac OS X 10.9 used to propose to install Java 6 after user confirmation, while Mac OS X 10.10 makes it less easy by sending the user to a page where he can download Java 6. Installing Java 6 won't put your computer at risk, since it can be used only for applications and not for applets in web browsers which encountered some security problems in the past years. I could bundled Oracle Java 7 or 8 like I did for the Mac App Store version, but creating one application able to switch between Oracle Java and Apple Java depending on the environment isn't easy. Maybe in the next version... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by naskar at Nov 21, 2014, 8:05:54 AM |
Re: 4.5 Portable Version asking por JAVA in MAC OS Ok, thank you very much! |
Current timezone is GMT Sep 1, 2026, 11:39:58 AM |
