Print at Oct 16, 2026, 9:52:34 PM
Posted by flany at Nov 21, 2014, 5:21:18 PM
How to fix a hole in the floor
Hello everyone, I've just discovered this amazing software and find it really easy to use but I cannot solve this:
I have an "L" shape stair with 3 steps straight and the Others to the left; over the first steps there is a ceiling (that is the first level floor!) but the software creates a hole over the Whole stair so on the first floor I have a hole in my bedroom laughing
is there a solution? could not find a way to "cover" the hole with the floor
Thank you.
Posted by okh at Nov 22, 2014, 8:50:57 AM
Re: How to fix a hole in the floor
To avoid the automatic cut-out of holes over a staircase:
- Select the staircase,
- Export selection as .obj.
- Import the .obj file without selecting the Staircase option.
- Draw the room on the floor above manually (to create a hole for the stairs).
Of course, there are more elaborate ways of approaching this, see the SVG Mini Manual for more.
See also thread,5478 (in FR - sort of ...).
BTW:
Make sure you leave enough headroom between the steps and the ceiling in the staircase. Not only is this a legal requirement many places, but banging your head in the ceiling above a staircase can hurt, badly. Grew up in an old house made for the vertically challenged. Permanent bump in the head.
