Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Integrating Sweet Home 3D Viewer in a webpage |
| Print at Oct 15, 2026, 10:27:15 PM |
| Posted by Puybaret at Nov 27, 2014, 4:27:50 PM |
Re: Integrating Sweet Home 3D Viewer in a webpage By the way, what make you think that you can't create folder in your website? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KenowaX at Nov 27, 2014, 4:59:53 PM |
Re: Integrating Sweet Home 3D Viewer in a webpage I asked the website developpers. They said that File Management was not implemented yet. And they do not know when it will be, if it will be. |
| Posted by KenowaX at Nov 27, 2014, 5:09:07 PM |
Re: Integrating Sweet Home 3D Viewer in a webpage I've read somewhere that Java 7 and UP have some issues with the ClassNotFoundException error. Apparently, uninstalling Java and installing Java 6 can solve the problem. However, I cannot ask everyone who will come to my website to uninstal Java 7 or 8 and replace it with Java 6. Would it be possible for you to sign the JAR files if I send them to you ? |
| Posted by Puybaret at Nov 27, 2014, 6:11:31 PM |
Re: Integrating Sweet Home 3D Viewer in a webpage Sorry I won't, just because I don't want my certificate to be used when there are other solutions. If you want to generate jar files yourself, download source code, install the JDK and Ant (or use eclipse), update the deploy/SweetHome3DViewer.jnlp file found in the project and run the Ant target viewerInstaller. The easiest solution could be to host simply your files elsewhere. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 15, 2026, 10:27:15 PM |
