Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Question: testing the plug-in |
| Print at Oct 2, 2026, 9:38:09 PM | |
| Posted by mgxcsd at Dec 29, 2014, 10:31:09 AM |
Question: testing the plug-in According to Plug-in developer's guide, created a jar file at the plugins folder right? And when run it with the command: java -jar /path/to/SweetHome3D-4.5.jar(or by double-clicking on it), nothing happens ! What am I doing wrong??? |
| Posted by Puybaret at Dec 29, 2014, 8:54:23 PM |
Re: Question: testing the plug-in Add some log or run it with the debugger as indicated in the Plug-in developer's guide to be sure it's taken into account at launch time. If you want to be sure it's in the right place, add an existing plug-in and check yours and the existing one are in the same place. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mgxcsd at Jan 2, 2015, 9:59:22 AM |
Re: Question: testing the plug-in I did everything but again nothing! Only the existing plug-in appears,and not mine!...Some time ago my plug-in worked, and when for some reason change the workspace,my plug-in stop to work. I tried to restore( ) the situation, but nothing! ![]() |
Current timezone is GMT Oct 2, 2026, 9:38:09 PM |
