Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Reality Check |
| Print at Sep 29, 2026, 9:55:35 PM |
| Posted by biko at Jan 27, 2015, 3:54:48 PM |
Re: Reality Check wow |
| Posted by anhmax at Feb 15, 2015, 12:44:51 PM |
Re: Reality Check Can you show me your pc reqs (cpu, gpu, ram)? I think 3D Sweet home isn't powerful enough to render this pic. ---------------------------------------- My channel: https://www.youtube.com/channel/UCM1mqUjGRtD4uCXX5qzgG3w |
| Posted by slimpy at Feb 15, 2015, 9:18:26 PM |
Re: Reality Check No idea how you came to the conclusion that SH3D isn't powerful enough to render this pic. The computer that rendered this was a HP laptop sporting an Intel i7-4700MQ quad core processor and 8GB RAM. SH3D is configured to use a maximum of 4GB of RAM. The graphic card (although completely irrelevant for rendering at the two best quality settings) is an integrated Intel HD Graphics 4600. There is also an unused (disabled) Nvidia GeForce GT740M graphic chip. This computer runs Linux (Opensuse) as its operating system. The SH3D file has a size (compressed) of 62MB. As posted previously it takes about 2 hours to render this pic at a size of 3600x2133px. Best, slimpy |
| Posted by sjimran at Feb 17, 2015, 3:47:01 PM |
Re: Reality Check use virtual memory to increase the RAM. |
| Posted by slimpy at Feb 17, 2015, 9:03:20 PM |
Re: Reality Check use virtual memory to increase the RAM. Why should I do this? I only use half of the available memory for SH3D and I don't have any issues at all. Paging to slower swap memory doesn't sound like a good idea... |
| Posted by taltan at Mar 4, 2015, 7:05:51 AM |
Re: Reality Check Hi! Just wondering how did you create your books and other elements of your projects? Eg book shelf.. sofa.. how are they so exact? Many thanks! |
| Posted by jpcr at Mar 4, 2015, 10:12:33 AM |
Re: Reality Check amazing. i never get close to realistic in my tests , but here : wow ! jp |
| Posted by Desslok at Mar 4, 2015, 4:43:36 PM |
Re: Reality Check Hmmm. You've given my something to think about in my Enterprise renders. I've been having trouble getting my ceiling textures to show up. They appear quite dark even when everything else in the room is well lit. I hadn't considered 'ambient light'. I will have to experiment with that. Thanks. ![]() |
| Posted by slimpy at Mar 5, 2015, 12:19:01 AM |
Re: Reality Check Hi! Just wondering how did you create your books and other elements of your projects? Eg book shelf.. sofa.. how are they so exact? Many thanks! I used different tools to model the furniture, Art of illusion (windows, sideboard, coffee table, loudspeakers), clara.io (sofa, toy box, fireplace, lamps, painting) and Blender (book shelf, bumper car) The sofa for instance is a rather simple model using cubes with some bevelled edges. What makes it look realistic are the textures based on images of the actual fabrics of the sofa. The books are also merely boxes with an applied image texture. Only the book spines and the first cover and last back are textured. However, getting the UV layout right for every single book was a rather tedious job. |
| Posted by Desslok at Mar 5, 2015, 4:22:59 PM |
Re: Reality Check Concerning the books textures. I have worked out an easier way to correctly map simple textures like that. I don't use Blender. Instead, I take the original texture and import it into Sweethome3d. I size it in the editor, making note of the dimensions. Then I add a box and resize that to match the dimensions of the texture. Then I apply the texture. Then I export the box as an object. Then I can import it into Blender and place it on the bookshelf as I want it. Repeat for the other books. When all is as I like it, join all into a single object and export as object format again. Then import into the Sweethome3d Library editor. It will come in with all textures correctly oriented. ![]() |
Current timezone is GMT Sep 29, 2026, 9:55:35 PM |
