Print at Oct 17, 2026, 8:40:41 AM
Posted by santbose at Jan 21, 2015, 6:09:03 AM
confused   Inclined wall at 45 degree with the ground
Hi All..... first thing first. I am using this wonderful software for last couple of months. I must say I am enjoying it very much. I am designing a sports centre with swimming pool in it. In the plan I need to front wall of the main lounge to be inclined as below in an angle of say 45 degree with the ground level:
/wall
__/_________ground (lawn)__________________
Can any one help me with this please. Once I finish the project drawings will definitely share it in the forum.
Santanu Bose
India
Posted by okh at Jan 21, 2015, 4:20:54 PM
Re: Inclined wall at 45 degree with the ground
Alas, standard walls cannot be angled, but using the roof principle, the fix is relatively easy: Draw the wall, insert windows, select wall+windows, export selection as .obj, import and rotate. Then you need to angle (slope) the ends of the joining walls (if the angle leans inwards) or fill gap with triangles (if it leans outwards).
Posted by santbose at Jan 22, 2015, 5:25:11 AM
Thanks Okh. Will try and get back.
