Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: FurnitureLibraryEditor error |
| Print at Oct 2, 2026, 10:58:42 AM | |
| Posted by Lumaja at Jan 28, 2015, 1:47:40 PM |
FurnitureLibraryEditor error Ubuntu 12.04 Sweet Home 3D ver. 4.5 Double click on “FurnitureLibraryEditor-1.14.jar” shows error: FurnitureLibraryEditor-1.14.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit. What should I do now? |
| Posted by okh at Jan 28, 2015, 2:52:28 PM |
Re: FurnitureLibraryEditor error FurnitureLibraryEditor-1.14.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit. Assuming you get the file from the download page, make sure you have Java installed and adjust Java settings to allow the library editor to run. See also thread 4794 and there are other discussions on various Java releases for Ubuntu in the forum. okWhat should I do now? |
| Posted by Lumaja at Jan 30, 2015, 7:44:51 AM |
Re: FurnitureLibraryEditor error I have Java installed and SH is working I think it is Java 7. About adjust Java settings don't know how to do that, I changed the .jar into .zip but I think is not much of use. Went to properties Open with Open JDK Java 6 Runtime but the same error come up. |
| Posted by slimpy at Jan 30, 2015, 1:31:23 PM |
Re: FurnitureLibraryEditor error This is probably a permission issue in Ubuntu. Try to change the executable bit for FurnitureLibraryEditor-1.14.jar: chmod +x FurnitureLibraryEditor-1.14.jarBest, slimpy |
| Posted by Lumaja at Jan 30, 2015, 2:37:10 PM |
Re: FurnitureLibraryEditor error Thank you for your response. Terminal result: luis@luis-G41M-Combo:~$ chmod +x FurnitureLibraryEditor-1.14.jar chmod: cannot access `FurnitureLibraryEditor-1.14.jar': No such file or directory luis@luis-G41M-Combo:~$ The file is in “Home, Sweet Home 3D ver. 4.5 How I use this on command? |
| Posted by slimpy at Jan 30, 2015, 3:17:29 PM |
Re: FurnitureLibraryEditor error Switch to the directory first using the cd command: cd <path_to_directory>You can also change the file permissions in the properties dialog in your file manager (Dolphin, Konqueror, etc.). Best, slimpy |
| Posted by hansmex at Jan 30, 2015, 4:49:55 PM |
Re: FurnitureLibraryEditor error Easiest way to change Permissions in Ubuntu is: - select file - right-click and select Properties - choose tab Permissions - put a check in the box that says "Allow to run as program" (or something similar) - close the window. Now the file can be run as a program. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Lumaja at Feb 1, 2015, 6:02:07 AM |
Re: FurnitureLibraryEditor error Thank you it worked |
Current timezone is GMT Oct 2, 2026, 10:58:42 AM |
