Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: arch on half round wall |
| Print at Oct 17, 2026, 8:40:06 AM |
| Posted by bugarski.nenad at Feb 8, 2015, 11:09:37 AM |
arch on half round wall does anyone know how can i make/drow arch on a half round wall? tnx |
| Posted by okh at Feb 8, 2015, 10:42:32 PM |
Re: arch on half round wall After you have drawn a wall with correct endpoints, double-click (or select and Modify walls) to enter Arc extent in the wall properties. ok |
| Posted by bugarski.nenad at Feb 22, 2015, 11:53:31 AM |
Re: arch on half round wall that makes a half round wall. i know that. what i want is to make arch hole in that kind of wall... |
| Posted by changoel at Jan 10, 2017, 4:21:10 AM |
Re: arch on half round wall me too |
| Posted by bdfd at Jan 10, 2017, 4:22:36 PM |
Re: arch on half round wall If I understand correctly, you want to do that ? If yes, you can use the default object 'arch'. if no, you must create two walls* which will export in obj format. You import again the new object and when you see the green arrows, click on up right frame (front view) and then with the mouse and key shift click on the down green Arrow to have 90° and click enter... You'll have your half arch, see the joined file below. (*) First wall : standard Second wall : same than first but 'arc extent' = 90° and joins the twice. ![]() ---------------------------------------- ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Miker777 at Jan 10, 2017, 9:11:26 PM |
Re: arch on half round wall If you want to put the arch IN the curved wall, then i think you can create your wall, give it an arc, then position an arch , from the library, but turn the magnetism OFF, make the arch as big as is needed to create the opening. Mike |
| Posted by Miker777 at Jan 10, 2017, 9:43:55 PM |
Re: arch on half round wall Tried it and failed sorry, the opening that is created is rectangular, i will have a rethink. Mike |
| Posted by Miker777 at Jan 10, 2017, 10:54:05 PM |
Re: arch on half round wall I managed to make some thing that might do you, or at least give you an idea how you might achieve what you desire, here is a link to a sh3d file. Mike |
| Posted by Puybaret at Jan 15, 2017, 3:20:04 PM |
Re: arch on half round wall Nice attempt Mike. Of course, this workaround will work more or less well, according to the width of the arch and the curve of the wall... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Miker777 at Jan 15, 2017, 7:30:29 PM |
Re: arch on half round wall I know EP, but its all i could think of ![]() |
Current timezone is GMT Oct 17, 2026, 8:40:06 AM |
