Print at Oct 5, 2026, 3:22:53 AM
Posted by Raysab at Mar 21, 2015, 8:44:22 PM
Shipping container homes & solar panels
Hi People,
Love this Program but complete newbie. Maybe you can help me find some textures (wall) and furniture (object?) related to shipping containers building and solar panels.
Here’s some exemple of the matter:
Container homes
I need to render with metallic container look texture walls. I also need to integrate typical containers doors and add (sloppy) solar panels and wind mills to the assembly.
Should someone have a hint about this matter, your help will be greatly appreciated. Otherwise, please consider this as a request for smart developers ;)
Standard shipping containers measurements and details can be found everywhere on the net, here’s one exemple: Container details
Many thanks and keep the good work going.
Posted by okh at Mar 24, 2015, 10:37:09 PM
Re: Shipping container homes & solar panels
Guess you can find all that searching for container textures - and for models for wind turbines and photovoltaic solar/panels. You may also want to have a look at thread 4199. ok
Posted by Raysab at Mar 25, 2015, 8:14:32 PM
Wow, thanks Okh, I guess I missed key words in my search.
I went to do some photos of containers in my area in order to create some texture on my own. I succeeded having very nice picts and tried them as texture in SH3D but rendering was unconvincing. I guess there’s some resizing and format one need to apply before getting some good results ?
Thanks again.
Posted by okh at Mar 25, 2015, 10:11:00 PM
Yup, the resizing and orientation you need to figure out for yourself... smile
A couple of hints:
For the textures, either make it the same proportion as the surface, and import with same measurements as the surface - or more professionally, spend some time with a graphics editor and make a small seamless tile. Low resolution will usually do nicely e.g. 256x256 px or less for seamless.
As for the rotation of the solar panels, remember you can rotate the object by single degrees by pressing SHIFT when importing. That way you can get the panels correctly angled towards the sun - whichever latitude you may want to use for construction.
Best of luck!
Posted by Raysab at Mar 26, 2015, 10:08:13 AM
Thanks again Okh, I’m working on it :)
Another question if I may: is there a dedicated space in this forum, or in another place (Blog ?) where users display their SH3D work and share their findings ? This would be a very useful and nice place to discover the possibilities of this awesome program.
Posted by okh at Mar 26, 2015, 10:32:45 AM
If you look around the site/facebook page you will find some. The forum gallery may be the best place to start. ok
Posted by okh at Mar 27, 2015, 7:27:11 AM
Made me think, maybe not possible or a good idea (see thread 5794 - the below is one single very quick mock-up colourised. Small file sizes (500 bytes, 32x256 px - texture height should be set equal to wall/container height in SH3D). ok
SF 3D models 351:
Posted by Raysab at Mar 27, 2015, 5:41:58 PM
That GREAT :)
Now I understand what you mean by “tiles” :)
I’ll apply this to my drawings and will share it here.
Many thanks.
Posted by Raysab at Mar 30, 2015, 12:03:29 AM
Hi Okh,
I used your container textures for this project, the rendering is perfect when sticking to container measurements. Thanks again for your help. I attached a picture of my first sketch which might appear a bit awkward but it is a real-life project about a bio-farm to be implemented in Equatorial Africa.
Now I’m studying the way to build a multiple sloped roof made of solar panels on top the wooden carpentry structure I designed and destined to funnel, at the same time, heavy rain falls into the central “tube” in the middle of the plan (see picts).
I will get back with more, when possible.
My deep gratitude for your help and to this Forum.
Ray
PS: Oups sad I just noticed that I can’t just drop a pict here. Ok, I’ll work it out and see how to share my work here.
Posted by Puybaret at Apr 1, 2015, 7:02:25 PM
Please see this message for suggestions about adding images.
Posted by Raysab at Apr 2, 2015, 12:03:19 PM
Thanks for the tips. Here are the missing images I wanted to share with Okh regarding the container texture issue. As one can see, doors still work in progress :) I took some pictures of real ones then tried to resize in order to fit the drawing. Coloring is also to be worked on.
Now I have to draw this complicated multiple slopes roof covered with solar panels and funnelling rain water into the central tube seen on the first floor image. This big tube is linked to an underground mini hydro-turbine to produce electricity, before getting to another underground water storage.
This “technical” bio-farm project is to be located in an equatorial area of the Globe (I can't reveal the exact location for now) and must work totally off-grid, meaning generate all its energy needs. The present building is just the “administrative" unit.
Many tanks again for all your help.
Posted by VeroniQ at Apr 3, 2015, 5:06:21 PM
About Shipping container, watch this interesting new video
https://www.youtube.com/watch?v=_C2d3z0t67k smile
Posted by Raysab at Apr 3, 2015, 7:28:30 PM
Thx VeroniQ, I’ve seen this video already, very nice job indeed :)
I’m still in the early stages of learning SH3D functions and possibilities and it would take me sometimes to master the 3D video production. As for now, I’m trying to apply my ideas in designing container building which is the main goal for learning this beautiful program.
Here’s more of what I’m doing right now, it is built out of 4 x 40’ HC + 1 x 20’ containers:
You might be interested to have a glimpse on actual real container home building :)
And there’s much more to see here (my fav is #6)
Posted by okh at Apr 6, 2015, 1:40:49 PM
Very interesting project. Please, keep sharing.
(Can you really generate any worthwhile energy from the rainwater + mini hydro-turbine?)
Posted by Raysab at Apr 6, 2015, 3:09:33 PM
Thx Okh, I’ll do.
To answer your question: no, a mini-turbine out of rainfalls is not viable alone. However, the location is extremely wet 8 months/year and the roof is covered with Solar panels which would complete the turbine provision. But this is only for modest back up batteries. The main power source would come from a little but sufficient dam build on a nearby river, plus a good large wind mill fixed on a telecommunication tower. The whole built units are very frugal in term of Kw consumption. The hungriest appliances are the fridge, TV and computers. Temperature control inside the habitable containers (left and right) is provided by a well deployed geothermal system. For this, we use a small but powerful air or liquid pump which doesn’t require much power.
Does it make sens ?
Posted by okh at Apr 6, 2015, 5:16:43 PM
Thanks. Yes, that makes sense. As you are in an equatorial area I guess your kind of temperature control is different from my off-grid needs (Northern Europe, 975 m above sea level), but I am planning on testing reversible air collector: Heats air significantly in a panel, reverses the fan and sucks cold air from the shade for cooling. Even if this must be supplemented by wood-burning stoves in the cold season, apparently the effect is significant. Some tests indicate a panel air temperature increases of 20-35 deg C, in addition to reducing humidity. Or an effect of up to 750 W pr sq m of panel (as opposed to photovoltaic 200-250 W/sq m)). But best of all, the air collectors are very simple constructions.
Anyway, appreciate your updates. ok
Posted by Raysab at Apr 8, 2015, 3:51:21 PM
Niiice :) I’m glad there’s someone like you interested in off-grid building and I hope there’s many others in this Forum. Maybe is there a thread for it ? This would help implement new “obj”, textures and material in SH3D, just a thought.
As for your point on thermal issue, you need to know that I’m a Canadian (Québec) and face the same in my home country. There’s a large citizen movment toward off-grid endeavors and they are experimenting some very serious solutions. If you wish, I can send you some links. I know also a lot of people involved in the same field in Germany and France and producing some very convincing results. But I guess you know all that.
Posted by okh at Apr 9, 2015, 9:28:58 AM
I for one would be interested in any experience with off-grid systems (so yes, please send links). In general, energy supply is not as robust as one might think. A very cold, windless winter in Europe, combined with dismantling nuclear and unreliable supplies of fossil fuel, could be a challenge and maybe a lesson much needed. But with emergence of new solutions, some very cool alternatives are available for any on or off grid construction.
My primary interest now, however, is a small cabin > 5km from grid and no motorised access. It works well already with wood, candles and water from a stream (if not exactly family friendly). But development in LED, battery technology, photovoltaic, sun thermal collectors, etc. over the last couple of years means modern comforts can be made available off-grid. E.g:
  • Small photovoltaic system, 50w panel, 100 Ah battery capacity.
    (for 8 LED lamps + radio + charging mobile/gps)
  • Small power generator for topping battery and use of tools/water pump.
  • Additional self contained solar lamps for exterior lights.
  • Solar thermal collector (air) to raise base indoor temperature, improve ventilation and reduce humidity/condensation.
  • Hot water coil in wood-burner to provide for long, hot showers.
  • Cooking on gas (minimal consumption) will be kept.
The modest capacity is just a result of every component having to be carried several km in steep and rugged terrain. I have abandoned a few ideas that could be good elsewhere:
  • Wind turbines (too noisy, relatively low output, too many moving parts and bad for bats/birds).
  • Pico hydro systems (stream too far away, components too heavy, too much maintenance, frost proofing).
  • Water tank heating from solar collector in combination with wood stoves even if there are some very good maritime and residential solutions available (too complicated, requires frost proofing, constant electricity for pumps).
  • Roof water collection (requires frost proof tank, filtering system and a new roof...).
  • A mobile phone (gsm) controlled gas/paraffin stove to pre-heat the cabin before arrival (feel uneasy about starting an oven without knowing whether a bird has snuck in the chimney and built a nest on top of the stove, and I dislike carrying gas/paraffin).
  • Heat pump, also for refrigeration (too complicated/heavy and using snow or cold stream water is usually sufficient).
The main challenge is actually sewerage/septic. Solutions exist, but I would prefer a flushing toilet (e.g. marine style), but environmental requirements makes it almost impossible to create a legal, composting septic system. Even so, the bottom line is that, yes, it is possible to create a comfortable living environment with pretty simple technologies.
So, any experience with this, please share. I may be biased, but I think these topics are relevant in this forum; the changes in the way we use energy and how it is supplied, also has a high impact on how we design our living space. And what better tool to start sketching than SH3D. There are threads touching upon such issues, but dedicated threads (probably in SH3D forum Bar) would be welcome (for me, anyway).
SH3D used for planning
Posted by okh at Apr 9, 2015, 11:05:02 AM
Instead of moving further off topic, I started a thread with some elaboration of the above thoughts in the Forum bar: Off grid solutions (5826). ok
Posted by Raysab at Apr 9, 2015, 10:16:57 PM
Excellent move okh I’ll follow you there :)
Posted by Raysab at Apr 12, 2015, 9:31:35 PM
So here I am struggling with intricate sloppy roof... sad
However, I was able at least to draw a very comprehensive roof timber framing using sloppy wall, wood texture and the “invisible triangle” obj, for which I give a thumb up to the author applause
I tried working with the “sloppy ceiling & roof” tutorial provided by Hans Dirske and create obj for export, but it’s mission impossible in my case, obviously.
Anyway, here’s some picts to illustrate the issue.
Cheers
Posted by Raysab at Apr 12, 2015, 10:36:04 PM
Hi Okh,
I downloaded solar panels and wind mills from your suggested sites but they are all in .skp format not compatible with object import in SH3D.
Is there a way to covert into a usable format in SH3D ?
Thanks for your help.
Ray
Posted by hansmex at Apr 12, 2015, 11:54:16 PM
1 - Download and install the free version of Sketchup
2 - Open the model you need
3 - Export it in DAE or KMZ format
That's all.
Posted by homerbask at Apr 13, 2015, 2:27:00 AM
hello in https://3dwarehouse.sketchup.com/ can find thousands of models, if the shocks .KMZ the matter can SH3D hassle if you do not have to do as you did it would be best rooftop says hansmex the roof in sketchup and are importing a SH3D to place as sketchup has many possibilities to create from 0
Posted by Puybaret at Apr 13, 2015, 8:03:57 AM
Raysab, please see this message to handle correctly downloads on Trimble Warehouse 3D.
Posted by hansmex at Apr 16, 2015, 4:44:47 AM
A nice container home I made some time ago:
made of 4x40 foot, 2x20 foot container.
Posted by SixDice at Aug 13, 2015, 12:13:16 PM
Hello all,
I am also new to Sweet Home 3D but don't find it that hard. It a very straight forward software to use.
Reason for writing here is also I am designing and hopefully use my design to build my own container house. Am also trying to make it all self significant with electricity.
I just thought I should share with you here. I will try and post some images of what I have come up with.
Posted by Adolf08 at Aug 30, 2015, 9:44:15 AM
Very interesting.
Keep sharing.
Posted by ElfenM at Sep 7, 2015, 9:11:21 PM
Hello World, first post for me here...
Just jumping in, There are Insulated/Refrigerated shipping containers where the outside corrugated walls are filled in with foam and covered in plywood or metal. This is great that:
1) You have a smooth wall
2) The Wall is about 3 1/2 inches, same 'standard' wall thickness used in Sweet Home 3D.
Only problem is that it is a "Thick" Wall. But this makes it easy to use with the Sweet Home 3D program! (Note, most places I know just use a 2X4 stud and a 1/2in sheet rock/plaster board, making a thinner wall! It is very cheap construction!)
Most containers are 7ft tall, a bit confining for a guy like me who is over 6ft tall! But there are taller containers. I believe the tallest is 8'6".
I find Sweet Home 3D to be a great program, been using it for less than a year now in designing container and other types of homes for a few friends.
Keep up the great work guys! Great program! Great Homes!
Posted by ickle_bea at Dec 26, 2015, 8:04:03 AM
HI, I downloaded a few .skp files, downloaded Sketchup and tried exporting them in both those file formats as you suggested but SH3D won't recognise them.
Any suggestions?
Thanks
Posted by hansmex at Dec 26, 2015, 12:03:55 PM
Can you point us to the files you downloaded?
That way we can see where things go wrong.
Posted by ickle_bea at Dec 26, 2015, 3:25:26 PM
Hi
Thanks for your reply. There were a few. Here are a couple of those.
https://3dwarehouse.sketchup.com/model.html?id=a0b0f119b1befb0a6dc9ed11312148b8
http://telias.free.fr/models_wavefront_menu.html
Posted by hansmex at Dec 26, 2015, 4:09:54 PM
Sketchup - click the big red Download button at top-right, then select the Collada file. It imports correctly.
Telias - The first bed downloads and imports without any problem. If you have problems with a specific model, give a link to that model, not to the page.
Posted by ickle_bea at Dec 28, 2015, 10:57:12 AM
Hi, I have no problem with downloading anything from Sketchup or Telias. I downloaded a load of files from both of those.
My problem is that SH3D is not recognising the files. I try to import the .obj files and I just get a message saying it doesn't recognise the files. You can see in the screenshots.
Also when I try to open the files directly by right clicking on them and selecting the SH3D app to open them, it doesn't see the files that way either. No idea why.
http://s1057.photobucket.com/user/Beatrice_Flowers/library/screenshots
Posted by hansmex at Dec 28, 2015, 11:12:10 AM
1 - You complain about the Sketchup model. On my PC it imports correctly. That means the model is OK, and if it doesn't import correctly on your PC than (a) you are doing something wrong or (b) your PC is doing something wrong. Without more info it's impossible to say which is the case.
2 - Telia: without more specific info it's impossible to help you.
NOTE: think of the OBJ format as a language that describes a 3D shape. Every language has its dialects. Maybe some of the models on the telia website are in a dialect SH3D doesn't understand. This is a known problem with the OBJ format.
A possible workaround is to import the model in a different program, then export it again. You might give Blender a try, it supports OBJ and can export in several formats recognized by SH3D.
Posted by ickle_bea at Dec 28, 2015, 2:41:06 PM
Ok, Thank you. I will try Blender.
I am using a Mac, wonder if that has anything to do with it.
No worries anyway, will figure it out.
Posted by ickle_bea at Jan 2, 2016, 1:31:52 PM
Hi Hansmex
I figured out to import most of the files. A little unconventional probably but I found that if I made them into zip files first, it imported them from the zip files no problem.
So, all good. Thanks :)
