Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Wall (Стены) |
| Print at Sep 25, 2026, 9:02:10 AM | |
| Posted by ELITE83 at Mar 25, 2015, 7:47:10 AM |
Wall (Стены) Hello. Thanks for a great, convenient and simple program!! -- Have one request - to improve the mechanism of work with walls. Now the walls you can set the height on the edges and get a beveled wall. Please add 2 more options: 1) to set the height above the floor - this will allow you to make beams and other elements above the floor 2) to set the height above the floor for the beginning and end walls - then the mechanism of the walls to help to make virtually any geometric shape in space and immediately solve the complex problem of attics and ceilings /translation from Russian/ Здравствуйте. Спасибо за отличную, удобную и простую программу!! -- Есть одна просьба - доработать механизм работы со стенами. Сейчас стенам можно задать высоту по краям и получить скошенную стену. Пожалуйста добавьте еще 2 настройки: 1) задавать высоту над полом - это позволит делать балки и другие элементы выше пола 2) задавать высоту над полом для начала и конца стены - тогда механизм стен позволить сделать практически любую геометрическую фигуру в пространстве и сразу решит проблему сложных мансард и перекрытий |
| Posted by Puybaret at Mar 25, 2015, 8:26:44 AM |
Re: Wall (Стены) Sorry this won't happen. It would make the program too complicate. If you want to elevate a wall, put it on an upper level. If you want to create a hole in wall, use an invisible shape at its bottom. If you want to draw a complicate shape, use an other software, or draw more than one wall, or draw a room at an upper level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ELITE83 at Mar 27, 2015, 8:12:49 AM |
Re: Wall (Стены) maybe I haven't translated into English. I offer quite a bit to finalize the walls, so you can not only make the slope of the wall, lift the edge of the wall 1 This is already enough to make many complex elements! |
| Posted by ELITE83 at Mar 27, 2015, 8:34:02 AM |
Re: Wall (Стены) now ![]() please add ![]() raise in the beginning and raise at the end |
| Posted by hansmex at Mar 27, 2015, 8:59:03 AM |
Re: Wall (Стены) Yes, I would love that !! People have been asking this for many years... ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 25, 2026, 9:02:10 AM |
