Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Motor de render posible cycles? |
| Print at Sep 27, 2026, 10:00:42 AM | |
| Posted by cusa123 at Mar 27, 2015, 12:15:20 AM |
Motor de render posible cycles? Al parecer Amd pudieron parchear correctamente cycles para sus tarjetas. Ahora bien esto es posible trasladarse a sweet home 3d?.Ya que funcionan para Nvidia y Amd? ![]() |
| Posted by hansmex at Mar 27, 2015, 7:15:12 AM |
Re: Motor de render posible cycles? No estoy seguro si entiendo tu pregunta. 1 - SH3D usa todos los nucleos del processador cuando esta haciendo un render en nivel de calidad 3 o 4. 2 - SH3D no usa la tarjeta video para hacer los renders en ningun nivel de calidad. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by cusa123 at Apr 5, 2015, 3:12:44 AM |
Re: Motor de render posible cycles? The question is whether there is possibility of adding gpu render cycles? |
| Posted by hansmex at Apr 5, 2015, 8:41:06 AM |
Re: Motor de render posible cycles? No, that is not possible. --- No, no es posible. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by cusa123 at Apr 6, 2015, 12:18:51 PM |
Re: Motor de render posible cycles? What is required to accept sweet home 3d cycles? Que es lo que requiere sweet home 3d para aceptar cycles? |
| Posted by hansmex at Apr 6, 2015, 2:46:08 PM |
Re: Motor de render posible cycles? Podrias escribir un programa de extension que lo haga? = You could write an extension of SH3D that could handle the graphic processor(s)...? ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by cusa123 at Apr 7, 2015, 2:53:04 AM |
Re: Motor de render posible cycles? Dentro de blender vi un proyecto de cycles independiente. Dejame preguntar pero en general, es tipo java extencion la extencion para sh3d? ------------------------- In blender saw a project of independent cycles. Let me ask but overall is kind java extencion the extention to SH3D? |
| Posted by hansmex at Apr 7, 2015, 7:05:19 AM |
Re: Motor de render posible cycles? No lo se. Sugiero leer la(s) Guia(s) de Desarrolladores. = I don't know. I suggest you read the Developer's Guide(s). H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by cusa123 at Apr 7, 2015, 3:05:58 PM |
Re: Motor de render posible cycles? Al parecer puede que se interesen en sweet home java,no lo se. Pero un primer paso para que desarrolladores de blender ayuden es intentando de usar nativamente archivos (.blend) en sh3d. En si es molesto exportar y muchas veces no queda bien si eh visto un cycles externo. Puede ser el complemento que le falta a blender la parte de arquitectura o diseƱo para 3d casas,edificios,ect. [Note from moderator: removed French and English versions which didn't mean anything. cusa123, if you don't speak English or French, don't rely on automatic translations for technical subjects] |
| Posted by cusa123 at Apr 7, 2015, 3:37:08 PM |
Re: Motor de render posible cycles? Cycles Standalone Engine http://blenderartists.org/forum/showthread.ph...s-Standalone-Engine/page2 |
Current timezone is GMT Sep 27, 2026, 10:00:42 AM |
