Print at Sep 1, 2026, 4:00:41 PM
Posted by Chris308 at Apr 1, 2015, 7:07:52 PM
Need some furniture and other things, please help!
Hello everyone. There are several items of furniture and other things things that I need. I have a short list of things I need, in particular, an octagon-shaped Poker Table, some white, louvered French closet doors, etc. Does anybody know how I can contact someone to make them for me? I've done a search for them, but have been unable to find them. I cannot make them myself. Any help in this would be greatly appreciated.
Posted by slimpy at Apr 2, 2015, 2:52:03 PM
Re: Need some furniture and other things, please help!
Where did you look for those models?
A quick search in the 3D Warehouse returned various octagonal poker tables:
https://3dwarehouse.sketchup.com/search.html?...;btng=search+3d+warehouse
The same goes for louver doors
https://3dwarehouse.sketchup.com/search.html?...s&backendClass=entity
Best, slimpy
Posted by Chris308 at Apr 2, 2015, 3:21:16 PM
Thanx for the info. I checked out the ones you mentioned, but they don't seem like a file I can use in a sweethome3d house. Am I missing something? If so, please let me know what, and how to go about using them. I have other furniture and some textures I need as well.
Posted by Puybaret at Apr 2, 2015, 3:52:10 PM
In the current version of Trimble 3D Warehouse, you should first click on the image of a model, then click on Download red button to choose KMZ or Collada file format that is supported by Sweet Home 3D.
Said an other way:
Don't click on the symbol shown at the bottom left of model images:
NO
but click on model images themselves, then click on Download button and choose a file format supported by Sweet Home 3D:
YES
Posted by Chris308 at Apr 4, 2015, 1:33:03 AM
Thanx for the additional info. That helped a lot. I did have an issue with some files tho. They showed as KMZ files, but when I tried to install them, sweethome3d said they were not compatible. Any known reason for this? So far I've been able to fine quite a bit of what I was looking for. Will keep looking. One thing I am having a bit of trouble finding is a good texture for dark grey aluminum siding. I already tried one I have. It works, but not very well. Any thoughts where I can find one? Also, since I'm here, can somebody tell me how to add an 8" step up to a room, and add a roof? I haven't figured out how to do this yet. As usual, all help is very much appreciated.
Posted by Puybaret at Apr 4, 2015, 11:51:41 AM
Could you post here the URLs to the KMZ models that caused some problems, please?
Posted by hfrmobile at Apr 6, 2015, 10:06:25 AM
Some furniture and other things created by me:
https://3dwarehouse.sketchup.com/user.html?id...fb-48d9-bf44-5bc8d4838713
Maybe you find one or more of them useful. You can use the COLLADA-Format (.dae) for using my models in SH3D!
Posted by Chris308 at Apr 7, 2015, 8:58:18 PM
As a general rule, I delete the file if it doesn't work. One of the files is a 2012 Mercedes-Benz C63 AMG Sedan by Allabassiry. It says its a KMZ file, but if I try to install it, it says "the format of the chosen model isn't supported". Most of the other KMZ files I've tried have worked OK, but there have been other exceptions also. Unfortunately, I can't tell you which ones for the reason already stated. Will try to let you know of others if they show up. If the above file can be fixed, please let me know. Thanx.
Posted by Chris308 at Apr 7, 2015, 9:02:10 PM
hfrmobile, I looked up the files you mentioned. Some of them were very helpful. Thanx.
Posted by hansmex at Apr 8, 2015, 6:14:47 AM
You are right, the Mercedes model you mentioned cannot be imported in SH3D. A variation by another designer (but based on the same model) also cannot be imported. (Using SH3D 4.6 on Windows)
