Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Modify Room Function Not Working? |
| Print at Sep 26, 2026, 7:01:12 AM | |
| Posted by Altstatten at Apr 13, 2015, 3:50:28 PM |
Modify Room Function Not Working? Just installed v. 4.6 and all seems to be working well except that, and I am following the instructions in the provided help area, once I select a room (it's a single, 4-walled room) the Modify Room function in the Plan/Modify Rooms drop-down remains grayed out and unusable. I'm sure it's something simple but I cannot find the answer. Any clues appreciated. (My end goal is to get that window that allows me to create floors/textures and ceilings as well) Thanks! |
| Posted by hansmex at Apr 13, 2015, 4:11:36 PM |
Re: Modify Room Function Not Working? If you draw four walls, the space inside may look like a room, but for the program it is NOT a room. To create a room, use the Create Room button, right next to the Create Wall button. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by [email protected] at Jul 28, 2021, 2:55:14 AM |
Re: Modify Room Function Not Working? I'm having the same issue and I already created the room. |
| Posted by Puybaret at Jul 30, 2021, 8:10:16 AM |
Re: Modify Room Function Not Working? Do you mean you created a room with the Room creation tool, set the Select mode back and when you double click on the room nothing happens? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 7:01:12 AM |
