Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Translucency with new version |
| Print at Oct 17, 2026, 5:10:51 PM | |
| Posted by WriterBLAlley at Apr 24, 2015, 10:29:06 PM |
Translucency with new version Can anyone tell me why models made in a previous version now appear translucent, even though they are solid? The generated background is showing through my models. |
| Posted by WriterBLAlley at Apr 24, 2015, 10:30:35 PM |
Re: Translucency with new version Thanks in advance |
| Posted by digitaltrails at Apr 25, 2015, 1:24:05 PM |
Re: Translucency with new version If by models, you mean the walls of your house model, then check 3D view->Modify 3D View Walls transparency. If you mean furniture models, if you created your own furniture, check the .mtl file for a d transparency value - see http://www.sweethome3d.com/support/forum/viewthread_thread,1196 If neither of the above, I haven't a clue. Perhaps post a screenshot so that others have more to go on. |
| Posted by WriterBLAlley at Apr 25, 2015, 2:51:33 PM |
Re: Translucency with new version No. In a previous version I created a backdrop with the included 'BOX'. It worked perfectly. When I upgraded to a newer version, now the background bleeds through. The darker the more obvious it is, but even when ground and sky are set to white the line between them shows through. In 3D view I set it to solid, and set the BOX to mat and tried other textures and colors. It's as if I used the transparent BOX instead and colored it. |
Current timezone is GMT Oct 17, 2026, 5:10:51 PM |
