Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to delete remove hide dimensions |
| Print at Sep 30, 2026, 3:13:14 PM | |
| Posted by oakland602 at May 8, 2015, 4:53:30 AM |
How to delete remove hide dimensions I've been using "create dimensions" to measure items, to get them a certain distance from the wall for example. When I'm done with the dimensions, how do I get rid of them? |
| Posted by hansmex at May 8, 2015, 9:14:07 AM |
Re: How to delete remove hide dimensions Try this: 1 - select dimension 2 - press Delete H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by oakland602 at May 8, 2015, 2:16:45 PM |
Re: How to delete remove hide dimensions Thanks Hansmex, I'm needing some help with step 1. How do I select dimension? Every time I try it, I end up moving my floor or something else. I've tried clicking on the numbers with the select tool, and I've tried using the dimension tool. What am I missing? |
| Posted by Puybaret at May 8, 2015, 9:31:57 PM |
Re: How to delete remove hide dimensions Don't click on the number but on the lines themselves. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by oakland602 at May 9, 2015, 6:59:48 AM |
Re: How to delete remove hide dimensions Perfect! That's the trick. Thanks! Love the software. |
| Posted by iTwo at Sep 3, 2024, 6:58:10 AM |
Re: How to delete remove hide dimensions Is there a way to select ALL dimensions? |
| Posted by Keet at Sep 3, 2024, 7:12:00 AM |
Re: How to delete remove hide dimensions Not that I know of. The best way to handle this is to always put all dimensions on their own (same elevation) level. That way you can show/hide the level with dimensions or completely delete it. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Sep 3, 2024, 8:27:04 AM |
Re: How to delete remove hide dimensions You could select all the dimensions with Select Hide utilty plug-in developed by Dorin. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 3:13:14 PM |
