Print at Sep 29, 2026, 12:21:19 AM
Posts: 12   Pages: 2   [ 1 2 | Next Page ]
Posted by bertaudmarc at May 9, 2015, 1:03:02 PM
sweethome3d-4.6-linux-x64.tgz
I started with ./SweetHome3d, the splash screen is displayed and the application hang:
Java 3D: implicit antialiasing enabled
java.lang.RuntimeException: cannot load system cursor: CopyDrop.32x32
at sun.awt.X11.XToolkit.lazilyLoadDesktopProperty(Unknown Source)
Caused by: java.lang.RuntimeException: failed to load system cursor: DnD.Cursor.CopyDrop : cannot load system cursor: CopyDrop.32x32
at java.awt.dnd.DragSource.load(Unknown Source)
Posted by bertaudmarc at May 10, 2015, 1:51:39 PM
Re: sweethome3d-4.6-linux-x64.tgz
I tried to add the following option:
-Dcom.eteks.sweethome3d.no3D=true
but no effect.
Posted by Puybaret at May 10, 2015, 2:25:28 PM
The option you tried disables the 3D view, but the error you've got isn't bound to any 3D feature. I think the file you downloaded is buggy? Did you try to download Sweet Home 3D again?
Posted by bertaudmarc at May 12, 2015, 4:36:56 PM
I tried the 2D version according to the FAQ suggestion !
I think the error is bound to java
Posted by bertaudmarc at May 12, 2015, 4:40:12 PM
Could you suggest me a reliable link to download sweethome3d-4.6-linux-x64.tgz !
Posted by Puybaret at May 12, 2015, 5:07:30 PM
Use the links in Download page.
Posted by bertaudmarc at May 13, 2015, 12:20:20 AM
That was my source !
I downloaded again, uncompressed in another folder, executed it but always the same error.
Problem of graphic driver ? (mga200 is very old ...)
Posted by Puybaret at May 13, 2015, 2:29:17 PM
Try to search your error in Google. You might have interesting answers like this one.
Posted by bertaudmarc at May 14, 2015, 1:45:02 PM
I solved the problem like this:
I modified the mgag200 option to 0 in the modesetting.conf file !
But I lost high resolution of my screen ...
Many thanks to Emmanuel.
Posted by Puybaret at May 14, 2015, 7:59:31 PM
Thanks for your feedback.
In the future version of Sweet Home 3D, there are some chances that under Linux and Windows, there will be an update of the version of Java3D, the library used for the 3D view. Please, try again once it will be released to see if it works better.
