Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Turning on lighting. |
| Print at Sep 1, 2026, 12:23:55 PM | View all posts in this thread on one page |
| Posted by Bojoglobe at May 24, 2015, 9:02:55 AM |
Turning on lighting. HI all, Great program, thanks to the developers. If you could help, I'm a newbe and can't make the lights "work", I can't find a way to make it appear they are working or showing any glow. I have done a lot of searching but can't find a direct answer. I'd appreciate some direction please. Thanks Bob |
| Posted by Puybaret at May 25, 2015, 9:41:24 AM |
Re: Turning on lighting. Until now, lights never glow in the 3D view and you can see their effect only in the photo creation tool when you choose one of the 2 best qualities. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bojoglobe at May 25, 2015, 10:51:30 AM |
Re: Turning on lighting. Thanks Emanuel, Much appreciated, I'll check that. Bob |
| Posted by mazoola at May 25, 2015, 11:09:44 AM |
Re: Turning on lighting. Bob - As someone currently stuck using an underpowered, backup PC, I usually run a quick 'lighting check' run at low resolution (200 to 300 pixels wide) and level 3 quality; that's usually enough to sanity-check most lighting options. (IIRC, only a few, higher-level ray-tracing features [reflection, refraction] show up only at level 4.) Once I've adjusted lighting to eliminate burnout and shaded areas, I render at full size and level 4. Maz |
| Posted by mazaya at May 30, 2015, 9:17:19 AM |
Re: Turning on lighting. I'll check that. |
Current timezone is GMT Sep 1, 2026, 12:23:55 PM |
