Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: advice needed |
| Print at Oct 18, 2026, 4:48:43 PM | |
| Posted by [email protected] at Jul 20, 2015, 11:41:49 PM |
advice needed I am working on a design for a small greenhouse... want to know how to go below ground? |
| Posted by Puybaret at Jul 21, 2015, 9:00:25 AM |
Re: advice needed Add a level and change its elevation to a negative value. Then in Virtual visit mode, you can below the ground and all objects you'll add to this underground level (a closed set of walls, rooms, furniture) will create a hole in the ground. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 18, 2026, 4:48:43 PM |
