Print at Sep 30, 2026, 3:12:44 PM
Posted by thomas52 at Aug 18, 2015, 12:04:27 AM
Flip door
I know how to rotate a door, but how do I flip the door, so the door swings DOWN instead of up? Thanks,
Posted by hansmex at Aug 18, 2015, 8:47:16 AM
Re: Flip door
My guess is that you want to know how to open the door in the room and not, say, in the hallway?
When placing the door, wiggle a bit with your mouse. You will see that the door can be inserted opening towards either side of the wall.
Posted by thomas52 at Aug 18, 2015, 10:06:48 AM
Re: Flip door
I can rotate the door 360 degrees, and I can re-size the door, and I can move the door. If I open the door and stand with my back to the hinges, and if the door is on my left, it is a left-hand door. I have a right-hand door, and I need a LEFT-HAND door. "Wiggle a bit" doesn't seem to work.
Posted by hansmex at Aug 18, 2015, 12:37:13 PM
Re: Flip door
Then most probably you need Modify furniture --> Mirrored shape and (un)check the little box.
Posted by thomas52 at Aug 18, 2015, 1:20:37 PM
Re: Flip door
Got it, thank you. :)
Posted by hseiden at Oct 12, 2015, 9:08:28 PM
Re: Flip door
Good suggestion. As it is not furniture, just didn't seem that obvious! Thanks.
