Print at Oct 17, 2026, 9:46:44 AM
Posted by Hymer at Aug 29, 2015, 8:15:07 AM
Is it possible to create curved wall?
I should like to draw a wall on a sector base. The wall is vertically straight, as usual, but the base of it will be curved. Is there any solution?
Posted by okh at Aug 29, 2015, 10:15:02 AM
Re: Is it possible to create curved wall?
The wall tool-tip describes curved walls: Use CTRL (ALT on a Mac) when clicking end-point of wall, or enter the Arc extent in positive or negative degrees in wall properties later. To get a room to follow the curve, you need to auto-create: double-click with room tool within the room (must be closed). For windows and doors, some additional effort may be required, see thread 4840 with links to some possible solutions. ok
Posted by Hymer at Aug 29, 2015, 4:27:33 PM
smile   Re: Is it possible to create curved wall?
Thank you, okh. Sweethome is a wonderful program.
