Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Problem when exporting to OBJ |
| Print at Oct 1, 2026, 2:44:49 AM |
| Posted by agiofelipe at Sep 3, 2015, 1:50:02 PM |
Problem when exporting to OBJ Hello friends, I am constructing a roof from one wall: I am exporting to OBJ, the problem appears when I try to import furniture, a portion of the soil appears next to furniture: Anyone know how to fix this? sorry my bad english. |
| Posted by hansmex at Sep 3, 2015, 2:04:16 PM |
Re: Problem when exporting to OBJ Before exporting, select the object that you want to export. When exporting, choose Export selection. Now the piece of floor will not be exported. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by agiofelipe at Sep 3, 2015, 2:35:22 PM |
Re: Problem when exporting to OBJ Hi, I'm not finding the option Export selection: ![]() thanks for the quick response. |
| Posted by hansmex at Sep 3, 2015, 3:03:44 PM |
Re: Problem when exporting to OBJ Click on Export, then look again...... ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by agiofelipe at Sep 3, 2015, 3:25:44 PM |
Re: Problem when exporting to OBJ I am not found this option ![]() |
| Posted by hansmex at Sep 3, 2015, 3:58:17 PM |
Re: Problem when exporting to OBJ Interesting. I checked in my version 5.0, and indeed this option doesn't appear. Maybe something went wrong. @Emmanuel, is this a regression, or are we doing something wrong? I checked in v4.5 and it doesn't show the option either. Hans UPDATE Ooops, I'm being stupid. Click SAVE and the option appears. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Sep 3, 2015, 10:06:35 PM |
Re: Problem when exporting to OBJ I just checked and got the question dialog box asking to export the selected items or all the home. Strange... ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by agiofelipe at Sep 4, 2015, 1:02:11 AM |
Re: Problem when exporting to OBJ how do I know which version I am using? |
| Posted by okh at Sep 4, 2015, 9:54:54 AM |
Re: Problem when exporting to OBJ Use Help-About to get info about SH3D and Java versions. I get the Export selection option with Sweet Home 3D ® Version 5.0 Java version 1.8.0_51 / 32 bit / 0.6 GB max Tried different combinations of furniture, furniture+walls etc - and export/import obj works normally. IF there is a selection, the Export selection option appears (after overwrite) when saving/exporting. ok |
| Posted by agiofelipe at Sep 7, 2015, 12:30:58 PM |
Re: Problem when exporting to OBJ My version is still 3.7 I will upgrade to the latest version. |
Current timezone is GMT Oct 1, 2026, 2:44:49 AM |
