Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I swap the door opening (not just rotate the door on the wall/frame? |
| Print at Sep 27, 2026, 8:22:45 PM | |
| Posted by hseiden at Oct 12, 2015, 8:50:57 PM |
How do I swap the door opening (not just rotate the door on the wall/frame?I want to change the door opening from left handed to right handed, vice versa. How do I do that? |
| Posted by HawkDawg at Oct 13, 2015, 7:10:33 AM |
Re: How do I swap the door opening (not just rotate the door on the wall/frame? See this topic. http://www.sweethome3d.com/support/forum/viewthread_thread,6090 ---------------------------------------- Hawk |
| Posted by okh at Oct 13, 2015, 7:18:10 AM |
Re: How do I swap the door opening (not just rotate the door on the wall/frame? Make sure plan is unlocked, Modify furniture, check Mirrored shape. Direction of door: move towards one of the wall sides or change angle in Modify furniture. Door openings need SH3D extra properties to be visible (not directly imported OBJ, DAE, KMZ, 3DZ or ZIP files). ok |
| Posted by hseiden at Oct 13, 2015, 12:14:00 PM |
Re: How do I swap the door opening (not just rotate the door on the wall/frame?Yep. that did it. Thanks! Now, do you know where I can find a template for a bifold door? I have a need for a two section single door for a closet. Also a clear shower door. Any further help appreciated. Henry |
| Posted by HawkDawg at Oct 13, 2015, 1:06:24 PM |
Re: How do I swap the door opening (not just rotate the door on the wall/frame? There's a shower door on this page of the SH3D website. Just scroll down a bit. It's in the first category. I don't know if it's clear or not though. I haven't tried that one particular model. There's also a few links at the bottom of this page of the SH3D website. I've been to all of them but I don't recall seeing a two section single door at any of them, but there is a ton of stuff that might interest you. You'll just have to scope them out. ---------------------------------------- Hawk |
Current timezone is GMT Sep 27, 2026, 8:22:45 PM |
