Print at Sep 28, 2026, 11:34:46 AM
Posted by santhosh.chellamani at Oct 21, 2015, 2:24:07 PM
Keys.p12 certificate error..
hi,
i am getting error while trying to run ant 'applet' on my command line.
error related to the certificate generated.
command used to generate : keytool -genkey -keystore keys.keytool -alias SweetHome3D
and certificate generation i have renamed the file as keys.p12
kindly help.
Regards,
santhosh
Posted by santhosh.chellamani at Oct 21, 2015, 2:25:25 PM
Re: Keys.p12 certificate error..
this is the final error.
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: DerInputStream.getLength(): lengthTag=109, too big.
BUILD FAILED
Posted by Puybaret at Oct 21, 2015, 7:10:59 PM
The command used to generate the keys.p12 file is incorrect. As explained in the README.TXT file, it should be:
keytool -genkey -keystore keys.p12 -alias SweetHome3D -storetype pkcs12
Posted by santhosh.chellamani at Oct 26, 2015, 5:54:17 AM
Thank you so much for the support, i was successful in deploying SH3D on my server.
I am able to open the applet on my server, but i am not able to import libraries.
Can you please help me in guiding how to include libraries to my online version.
Thanks and Regards,
Santhosh C
Posted by Puybaret at Oct 26, 2015, 10:36:59 PM
See this subject.
