Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Furniture Library Problems |
| Print at Sep 27, 2026, 3:01:53 PM | |
| Posted by WiccanPriest at Nov 12, 2015, 11:56:34 PM |
Furniture Library Problems Hello there, Sorry to bother you but I have been trying to install the Furniture Library without any success at all. I am running Windows 10, if that makes a difference... My problem I download and install the furniture library When I click on the download, it will just not run. Nothing happens. I downloaded Java, multiple versions, and still can't figure out why the library will not run! |
| Posted by Puybaret at Nov 13, 2015, 12:32:36 PM |
Re: Furniture Library Problems If the extension of the file you downloaded is .zip, you should open it and extract from it the library file with a .sh3f extension. Then, select that file in the file dialog box shown by the Furniture > Import furniture library menu item in Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by WiccanPriest at Nov 13, 2015, 3:52:24 PM |
Re: Furniture Library Problems Oh Well I was doing it all wrong ..And here I was, thinking I was computer savvy I'd give it a go, again. Thanks! |
| Posted by WiccanPriest at Nov 13, 2015, 3:56:53 PM |
Re: Furniture Library Problems Ok, I just realized I made a mistake. It is NOT the furniture library I have problems with, is the Furniture Library EDITOR... I CANT install it |
| Posted by WiccanPriest at Nov 13, 2015, 4:22:46 PM |
Re: Furniture Library Problems I can't delete this thread, or edit the title to fix my mistake. I have posted with the actual problem, my bad. |
Current timezone is GMT Sep 27, 2026, 3:01:53 PM |
