Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: JAVA: How to change the default furniture catalog? |
| Print at Oct 7, 2026, 5:46:15 AM | |
| Posted by Sweeto at Nov 24, 2015, 4:41:59 PM |
JAVA: How to change the default furniture catalog? Hello guys, I want to modify the default folders and furniture, that are displayed on startup. I have set up Sweet Home 3D in Eclipse. I am fairly new to Java, I must confess. What I have found so far is this post: http://www.sweethome3d.com/support/forum/viewthread_thread,2422#10982 , but it explains, how to remove the default folders completely by editing the build.xml file. The previously mentioned post let me to the location, where I could change the folder's and furniture's names: D:\Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io You can also find the DefaultFurnitureCatalog class at this location. Could you please point me in the right direction? What do I have to do to add my own furniture models to the default menu? Is there another config file? In which folder do I have to put the model files? Greetings, Sweeto |
| Posted by Sweeto at Nov 26, 2015, 10:00:53 AM |
Re: JAVA: How to change the default furniture catalog? Ok, I've finally found the right file, where I can set the path of the default furniture files. Apparently all furniture files, that have been added in this file, have the extension ".obj" (exception: the light sources are also categorized as furniture, but they don't have an obj-file). 1. All files, that are nessesary to change the default categories/folders and default furniture are in this folder or in it's subfolders: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io1.1 All of the model files (.obj) and preview images (.png) are at this location: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io\resources1.2 All of the contributed model files and preview images are at this location: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io\resources\contributions2. Some files from the io-folder (see above): 2.1 ContributedFurnitureCatalog.properties (used to set the path, size,...) id#1=Sheep#spiralStaircase2.2 ContributedFurnitureCatalog_de.properties (language file, used for translation only) name#1=Wendeltreppe2.3 DefaultFurnitureCatalog.properties 2.4 DefaultFurnitureCatalog_de.properties |
| Posted by Sweeto at Nov 26, 2015, 1:34:17 PM |
Re: JAVA: How to change the default furniture catalog? The function readDefaultFurnitureCatalogs in Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io\DefaultFurnitureCatalog.java |
| Posted by Sweeto at Nov 26, 2015, 2:55:33 PM |
Re: JAVA: How to change the default furniture catalog? At first I have added the obj- and png-files to this folder: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\io\resourcesAnd edited the language property file and the normal property file (see above) in: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\src\com\eteks\sweethome3d\ioBut it did not work. Then I have added the obj and png-files to this folder: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\classes\com\eteks\sweethome3d\io\resourcesAnd edited the property files in: Now it works! :) What is the right way to do this? Do I really have to add the obj and png files in the classes folder (it doesn't make sense to me)? I am sorry, for those basic programming questions. |
| Posted by digitaltrails at Nov 26, 2015, 11:21:13 PM |
Re: JAVA: How to change the default furniture catalog? The properties and resources in the source (src) hierarchy are copied to the build output class hierarchy when the software is built by the build process. You would need to run ant to do a build. |
| Posted by digitaltrails at Nov 26, 2015, 11:23:30 PM |
Re: JAVA: How to change the default furniture catalog? The properties and resources in the source (src) hierarchy are copied to the build output class hierarchy when the software is built by the build process. You would need to run ant to do a build. I should have mentioned - see "copy todir" in the build.xml file. |
| Posted by Sweeto at Nov 27, 2015, 5:02:56 PM |
Re: JAVA: How to change the default furniture catalog? Hello digitaltrails, thank you for your answer. I have watched this video to understand how to build a project with ant: https://www.youtube.com/watch?v=qOhfl9gayB8 The options for an ant build are in the "build.xml"-file, which is located in this folder: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\ The "build.xml"-file does not contain any command, that will tell ant to copy files to this folder (the default output folder of my eclipse project): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\classes Instead ant copies the files to this folder (the build folder gets deleted at the end of the build process): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\build\classes I could add <copy todir="classes\com\eteks\sweethome3d\io\resources"> Have a nice weekend! Greetings, Sweeto |
| Posted by digitaltrails at Nov 29, 2015, 4:26:42 AM |
Re: JAVA: How to change the default furniture catalog? I assume you're using eclipse. The directory SweetHome3D-5.1-src/classes is used by eclipse to store class files it compiles. This is used by internally by eclipse, and also when running/debugging from within eclipse. Eclipse automatically includes the Project's source folders in it's run class paths, so it it is unnecessary to copy source resources and property files to eclipse's class folder. If you wanted to use eclipse's class folder outside of eclipse, you could do what eclipse does, and add the src folder to the class path of your java command (then both will searched). If I wanted to run outside of eclipse, I would build with ant and create all the necessary jars in the output build folder, then put the jars on the classpath (using the run scripts in the install folder as a guide). In practice, I just copy jars from the Ant build into my original "official" SH3D installation replacing the official ones with my own. Note: Ant builds are a separate thing from eclipse's automatic compiles. Eclipse uses it's own compiler, own dependency tracking, and own classpath definitions, all normally quite separate from Ant's. Plus eclipse also has it's own separate run/debug-time classpaths. Keeping eclipse and Ant in agreement is a headache - various tools are available to help better integrate eclipse with external build tools such as Ant, but none are completely perfect. It's not uncommon to burn time on sorting out dependency problems when eclipse and the external build tools get subtlety out of sync. Hello digitaltrails, thank you for your answer. I have watched this video to understand how to build a project with ant: https://www.youtube.com/watch?v=qOhfl9gayB8 The options for an ant build are in the "build.xml"-file, which is located in this folder: Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\ The "build.xml"-file does not contain any command, that will tell ant to copy files to this folder (the default output folder of my eclipse project): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\classes Instead ant copies the files to this folder (the build folder gets deleted at the end of the build process): Path_To_Sweet_Home_3D\SweetHome3D-5.1-src\build\classes I could add <copy todir="classes\com\eteks\sweethome3d\io\resources"> Have a nice weekend! Greetings, Sweeto |
Current timezone is GMT Oct 7, 2026, 5:46:15 AM |
