Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: STRG+E don't work anymore? |
| Print at Sep 26, 2026, 5:44:23 PM | |
| Posted by LillyDu at Jan 1, 2016, 12:40:37 PM |
STRG+E don't work anymore? Hi, I used the program for some weeks and all worked fine (I use Ubuntu). I installed the latest version from the SweetHome3D homepage. But since yesterday, I can't change the attributes neither for walls nor for furnitures. Also I can use drag and drop from the left menu. I can only add furnitures to the plan via the menu. Did I set a change somewhere? Do you have an idea? Thank you in advance for your ideas. |
| Posted by okh at Jan 2, 2016, 9:40:03 AM |
Re: STRG+E don't work anymore? You probably thought of this, but you may have locked the plan (the small padlock in top left plan corner)? But that should not affect all furniture, only the base plane ones, so that may not be it. ok |
Current timezone is GMT Sep 26, 2026, 5:44:23 PM |
